hyd seal
trainman
PostPosted: Thu Jan 17, 2013 6:43 pm    Post subject: hyd seal Reply to specific post Reply with quote
my ford 640 has a front loader made of steel tubing ,the hyd fluid is stored in the right side lift arm .the pump for the loader is set in front of the radater grill, I cant find the seal that slips on this shaft for this external pump. thanks for any help.
p.s id is 3/4 od is 1-3/8.
GlenIdaho
PostPosted: Thu Jan 17, 2013 6:55 pm    Post subject: Re: hyd seal Reply to specific post Reply with quote
If I understand you correctly, you need a seal for the pump. Over the years the pump may have been changed out for another make. So, you need to determine the make and model of the pump. Contact you local hydraulics shop and give them the name and model of the pump and they may be able to help you with rebuild parts. If that does not work, pull the pump and remove the seal and take it to a bearing shop to see if they can match it.
TMFORDY
PostPosted: Thu Jan 17, 2013 7:22 pm    Post subject: Re: hyd seal Reply to specific post Reply with quote
Do you have a picture of the loader? Sounds like a wagner as a guess. I just came across a pump from a 6xx that had a wagner.. And I am in need of a couple 24" rears on rims.
gatchelguy
PostPosted: Fri Jan 18, 2013 7:12 am    Post subject: Re: hyd seal Reply to specific post Reply with quote
Measure the shaft and the bore with a dial caliper and call a bearing suppoy house.
