| Author |
Message |
Ethan Chamberlain Regular
Posted: Fri Jan 18, 2013 5:08 am Post subject: 1566 ih |
Hello
I'm looking at a 1566, and was about ready to buy it until we tried to start it and nothing at all happened. We cracked fuel lines at the head, and have fuel there. We can get it to turn over with the starter by jumping the terminals with a screwdriver, but it won't fire or even smoke. We even tried helping it with some ether, but it still didn't fire. I had new battery's in it, so it shouldn't be a cranking speed problem. I'm out of ideas. What do you guys think? |
| Back to top |
Posted: Fri Jan 18, 2013 5:10 am Post subject: Re: 1566 ih |
I can turn the key and get power to the gauges, but the pushbutton is gone, so that is why I have to jump terminals with a screwdriver. |
| Back to top |
El Toro Tractor Guru
Posted: Fri Jan 18, 2013 5:36 am Post subject: Re: 1566 ih |
I would walk away. Hal |
| Back to top |
dhermesc Tractor Guru
Posted: Fri Jan 18, 2013 5:45 am Post subject: Re: 1566 ih |
How cold was it where you were starting it? |
| Back to top |
Posted: Fri Jan 18, 2013 6:02 am Post subject: Re: 1566 ih |
It was somewhere around the 34 degree mark. |
| Back to top |
mkirsch Tractor Guru
Posted: Fri Jan 18, 2013 6:13 am Post subject: Re: 1566 ih |
It should've fired easily at 34 degrees.
Those IH 400-series engines are good cold starters if everything is working even close to right.
The 1066 only ever got started during the winter to run the generator or go on "rescue missions" when the spreader tractor got stuck. That tractor would always fire up even down into single-digit temperatures, with nothing more than a quick puff of ether, if that.
Unless you can get the tractor for scrap price plus the value of the tires if they're any good, walk away. |
| Back to top |
John A. Tractor Expert
Joined: 04 Oct 1999 Posts: 2299 Location: Florence, Tx
Posted: Fri Jan 18, 2013 6:22 am Post subject: Re: 1566 ih |
Ethan, Always look for the obvious first, know it sounds dumb, but make sure the throttle is correctly set so it is not in the Kill position. could be that is is hung up there.
If you are spinning the engine smartly, throttle is not in the Kill position and not getting some smoke there are probable Injection pump problems. Have the man adjust the price accordingly, or walk away.
Hope this helps
Later,
John A. |
| Back to top |
Posted: Fri Jan 18, 2013 7:32 am Post subject: Re: 1566 ih |
Her price was 3000. How does that sound? |
| Back to top |
MN Scott Tractor Expert
Joined: 31 Jul 2004 Posts: 2060 Location: Preston, MN
Posted: Fri Jan 18, 2013 7:45 am Post subject: Re: 1566 ih |
Don't know how familiar you are with IH tractors but the 66 series tractors have a safety switch on the clutch. You have to have the clutch fully depressed for the starter to engage. |
| Back to top |
DeltaRed Tractor Guru
Joined: 25 Feb 2010 Posts: 6406 Location: Delta,colorado
Posted: Fri Jan 18, 2013 7:57 am Post subject: Re: 1566 ih |
If no smoke,the throttle is in the 'stop' position;the thing was run out of fuel;the fuel system has lost prime(could be bad) ;the pump is shot(worse);The fuel filters are plugged,or frozen.Block of ice in the tank plugging the suction.These things are something to look at..... |
| Back to top |
Posted: Fri Jan 18, 2013 11:38 am Post subject: Re: 1566 ih |
I would agree but it still should have fired/smoked a bit with the ether. |
| Back to top |
scotc Tractor Expert
Posted: Fri Jan 18, 2013 8:43 pm Post subject: Re: 1566 ih |
Did you have the throttle wide open?
How did the air filter look? |
| Back to top |
kennell Long Time User
Posted: Sat Jan 19, 2013 6:05 am Post subject: Re: 1566 ih |
I'd buy it in a flash if the tires hold air and the tractirs complete. Kent |
| Back to top |
Posted: Sat Jan 19, 2013 6:48 am Post subject: Re: 1566 ih |
When I pulled the air cleaner out it was plugged off with silt. Even when I pulled both air cleaners out it still would not do anything. I had the throttle about half open. |
| Back to top |
Posted: Sun Jan 20, 2013 3:33 pm Post subject: Re: 1566 ih |
The pump advances when you open the throttle, they start way better full open. I learned that JD's are the opposite, they advance til it gets oil pressure, and giving it any throttle you lose the advance and they start like crp.
But it should have fired off with the ether, if you shot it in with the air filters out.
If there was dirt in the housing around the air filters, it could be the engine is damaged.
You are getting good flow out of the fuel tank? |
| Back to top |
