| Author |
Message |
Jim Carswell New User
Posted: Fri Jan 18, 2013 12:35 pm Post subject: Common causes of leaking carb? |
When I turn on my fuel valve gas starts leaking out from somewhere behind the carb, tractor doesn't start. Before I start taking it apart is there anything I should be looking for specifically? It sat outside all summer - maybe the gaskets/seals dried up?
TIA,
Jim |
| Back to top |
Dean Tractor Guru
Posted: Fri Jan 18, 2013 12:54 pm Post subject: Re: Common causes of leaking carb? |
Fuel leaking from the carburetor when the fuel valve is opened is usually caused by failure of the float valve system. This can be a sticking, or damaged float assembly, loose float valve seat, damaged float valve needle, dirt in the float valve, etc.
Dean |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50675 Location: Lake of the Ozarks area of MO
Posted: Fri Jan 18, 2013 3:23 pm Post subject: Re: Common causes of leaking carb? |
You say carb leaks from behind sounds like a bad or dried up carb gasket. But also as Dean said and may have a float sticking and since it sat a long time maybe ever very rusty in side which will cause odd problems |
| Back to top |
L. B, Regular
Posted: Sat Jan 19, 2013 1:19 am Post subject: Re: Common causes of leaking carb? |
Take it apart it needs service at this point anyway, 5 mins time and ya should have a idea. |
| Back to top |
Britcheflee Long Time User
Joined: 20 Aug 2007 Posts: 1415 Location: Placerville California
Posted: Sat Jan 19, 2013 8:24 am Post subject: Re: Common causes of leaking carb? |
| Jim Carswell wrote: | (quoted from post at 13:35:01 01/18/13) When I turn on my fuel valve gas starts leaking out from somewhere behind the carb, tractor doesn't start. Before I start taking it apart is there anything I should be looking for specifically? It sat outside all summer - maybe the gaskets/seals dried up?
TIA,
Jim |
When you take it apart remove the pin which holds the float in place and gently lift out the float and give it a shake - if it is heavy or you hear liquid sloshing around inside then you have a pinhole leak in the float - if that is the case you can get the gas out and once dry clean the area out and see if you can re-solder it - I was successful doing that to mine.
Lee |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
