Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
601 Workmaster industrial
Post new topic    Yesterday's Tractors Forum Index -> Ford
Fuddy Duddy
PostPosted: Fri Jan 18, 2013 7:25 pm    Post subject: 601 Workmaster industrial Reply to specific post Reply with quote
Would a 601 Workmaster Industrial be a good candidate to hang a small Ditch Witch Backhoe off of?
I does not come with 3 point or PTO. But does have a FEL on it.
Kirk-NJ
PostPosted: Sat Jan 19, 2013 3:30 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
I had a little davis backhoe on one of my 841's. These backhoes were also used on ditch witch. Mine ran off the loader pump. You will have to build some kind of frame for it.
Fuddy Duddy
PostPosted: Sat Jan 19, 2013 4:35 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
Yours look to be about the same size as mine.
Does the tractor handle it OK. I take it that it is permanently mounted?
Wonder if anyone has a drawing of how to make the frame or maybe a picture of one not mounted to the tractor.
Would an "industrial" tractor has a heavier duty axle or not?
601 Workmaster
Dean
PostPosted: Sat Jan 19, 2013 5:42 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
The pictured tractor does not appear to be an "industrial" model but rather an AG model.
FWIW, it has MF rear rims.
Dean
Kirk-NJ
PostPosted: Sat Jan 19, 2013 5:48 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
Yes it handled it ok. The mount was not permanent. I had a quick disconnent on the hydraulic line and pull 4 pins and you could disconnect the backhoe off the back and have access to your 3pt system.
Yes both the light and heavy industrial will have a different front axle. the HD industrial also had a frame.
Kirk
Kirk-NJ
PostPosted: Sat Jan 19, 2013 5:53 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
One another thing I would like to point out is that you won't have much of a reach with this backhoe. But it's good it tight areas and I had no trouble digging a 5' deep thrench for the water line for my wood stove.
Kirk
Fuddy Duddy
PostPosted: Sat Jan 19, 2013 6:53 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
He said it was an Industrial model with no PTO and No 3 point.
Any thing I could ask him to help identify it?
Has could I tell for sure if I go look at it if it is or not?
It is 68 miles away from me.
john in la
PostPosted: Sat Jan 19, 2013 7:28 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
They never made a industrial 601 only a ag version. They did make a striped down version of the 601 that did not have gauges; pto; or 3 point. That is what that tractor is. If it was a industrial version it would be called a 2000.
The light industrial 2000 made in the same time period with most of the same parts as the 601 had a solid non adjustable front axle and other beefed up parts.
With that said the only thing the light industrial 2000 has over the 601 ag is better front end loader use from a better front end axle. Both tractors need a backhoe that is well supported from the front end or loader frame. If you just hang the backhoe off the rear end you are asking for trans case trouble as the backhoe twist the tractor while in use. This cracks the trans housing.
Kirk-NJ
PostPosted: Sat Jan 19, 2013 8:09 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
The light industrial will have a one piece front axle, non ajustable.
They did make a heavy duty front end for the 601 for loader work. It should have a yellow tag label on both sides of the doglegs.
Kirk
souNdguy
PostPosted: Sat Jan 19, 2013 12:58 pm    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
i put a woods 6500 hoe on the back of an 850 and it works great!
mine was 3pt and I welded up a subframe.
GT65
PostPosted: Mon Jan 21, 2013 10:20 am    Post subject: Re: 601 Workmaster industrial Reply to specific post Reply with quote
John is a 100 % right! And whatever you do, don"t lift the back of the tractor off the ground with the out riggers(don"t know if these outriggers could do it anyway)
This goes for the front of your tractor with the FEL also; DO NOT LIFT OFF THE GROUND!!
GT65
