| Author |
Message |
Pete-IN Regular
Posted: Sat Jan 19, 2013 5:32 am Post subject: Gas Line Anti Freeze |
In really cold weather, I have always dumped a bottle of gas line anti freeze in my vehicle tank. It is mostly alcohol. With todays modern gas blends, it says at the pump they contain up to 10% alcohol. Am I wasting my effort? I have never had a frozen line on a vehicle. |
| Back to top |
IaGary
Joined: 14 Jun 2007 Posts: 7238 Location: North Liberty Iowa
Posted: Sat Jan 19, 2013 5:47 am Post subject: Re: Gas Line Anti Freeze |
Ethanol blended gas eliminates the need for gas line anti freeze.
Yup wasted effort and money.
Gary |
| Back to top |
bill mart Tractor Expert
Posted: Sat Jan 19, 2013 5:49 am Post subject: Re: Gas Line Anti Freeze |
different kind of alcohol, dont know it works the same way. Bill |
| Back to top |
John B. Tractor Expert
Posted: Sat Jan 19, 2013 5:57 am Post subject: Re: Gas Line Anti Freeze |
When it gets cold you see so many people dumping Heet into their gas tanks. Well when it's 0 degrees outside it's too late to pour it in. If there is water in the tank it needs to be tended to before the cold season arrives. Take some water and mix some heet additive with it. Shake it up then let it set and see what happens. It may surprise you! |
| Back to top |
Wayne in MN Long Time User
Posted: Sat Jan 19, 2013 6:13 am Post subject: Re: Gas Line Anti Freeze |
No need for any extra alcohol in the gasoline. 10% from the pump is quite sufficient to handle any water problems.
I have not used a gasoline drier product for 30+ years since Ethanol blended fuels came out.
PS: I live in West-Central Minnesota lake country. |
| Back to top |
Lamar Fudd Regular
Posted: Sat Jan 19, 2013 7:11 am Post subject: Re: Gas Line Anti Freeze |
| John B. wrote: | | (quoted from post at 14:57:00 01/19/13) When it gets cold you see so many people dumping Heet into their gas tanks. Well when it's 0 degrees outside it's too late to pour it in. If there is water in the tank it needs to be tended to before the cold season arrives. Take some water and mix some heet additive with it. Shake it up then let it set and see what happens. It may surprise you! |
IF you have a frozen gas line, that can of HEETŪ will travel to where the frozen area is, as it's heavier than gasoline, and dissolve the ice blockage. Hasn,t been necessary since 10% fuel came out. |
| Back to top |
gene bender Tractor Guru
Posted: Sat Jan 19, 2013 8:26 am Post subject: Re: Gas Line Anti Freeze |
With the 10% blend you wont have any problems. |
| Back to top |
JOCCO Long Time User
Posted: Sat Jan 19, 2013 8:47 am Post subject: Re: Gas Line Anti Freeze |
two thoughts here: if you have that much water in the tank it needs to be tended to anyway (disassembel and clean)!!! 2. lots of this stuff is like engine rebuilder in a can (snake oil) |
| Back to top |
Russ from MN Tractor Expert
Posted: Sat Jan 19, 2013 9:45 am Post subject: Re: Gas Line Anti Freeze |
Yes, we haven't used it in 30+ years, had some bottles on the shelf that evaporated without ever being opened! |
| Back to top |
Brad Buchanan Long Time User
Posted: Sat Jan 19, 2013 10:00 am Post subject: Re: Gas Line Anti Freeze |
yes.
Brad |
| Back to top |
Glen SW Wi Regular
Posted: Sat Jan 19, 2013 10:25 am Post subject: Re: Gas Line Anti Freeze |
When I was a sales rep for Sinclair Oil we used to call all those little cans on the shelf "Mouse Milk". The dealers liked it though because the profit margin was quite high. |
| Back to top |
showcrop Tractor Guru
Posted: Sat Jan 19, 2013 11:00 am Post subject: Re: Gas Line Anti Freeze |
I used to put in two bottles per year, and believed that I no longer needed it. A few weeks ago one cold evening, my wife's car started to miss occasionally. We stopped at a store, and I got a bottle and dumped it in and it has been good since. Could it be it just needed a five minute break. |
| Back to top |
rustred Tractor Expert
Posted: Sat Jan 19, 2013 11:53 am Post subject: Re: Gas Line Anti Freeze |
biggest thing is to keep your tank full of fuel, not on the empty side. ya i know what some will say , thats hard to do. its big temperature changes that produce condensation.
just like when it warms up outside you can see your fluid level in your tractor tires.
i have never once has a gas line freeze up, and do not use the stuff. |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23611 Location: in front of computer
Posted: Sat Jan 19, 2013 2:19 pm Post subject: Re: Gas Line Anti Freeze |
Only kind of alcohol to add to any fuel system, in particular any fuel system with any type of injection. Is IPA, isopropyl alcohol which is the least metal and plastic aggressive. |
| Back to top |
MarkB_MI Tractor Guru
Posted: Sat Jan 19, 2013 5:08 pm Post subject: Re: Gas Line Anti Freeze |
What problem are you trying to solve? The purpose of gas line antifreeze is to disperse water in fuel, but if you buy your gas from a reputable dealer and keep the gas cap closed, you shouldn't get water in your fuel.
A lot of people used to put gas line antifreeze in their fuel in the mistaken belief it would prevent carburetor icing. It won't, because carb ice is caused by water in the air freezing in the venturi, and gas line antifreeze will never prevent that. Carb ice is a thing of the past now, of course. |
| Back to top |
