| Author |
Message |
Broken dodge Guest
Posted: Sat Jan 19, 2013 12:47 pm Post subject: Wheel bearing assembly removal on 2001 2500 |
I'm trying to get this thing off! I've tried hitting the bolts with a socket on them, then got mad and hit the bolts directly after ruining a socket(only to ruin 2 bolts) and nothing. Can't get it to budge. All 4 bolts on the backside are loose and free, the big main nut came right off, the caliper is off. I've changed one of these before and all I had to do was smack the bolts and it popped out enough to get a chisel behind it. Any ideas? Do I need to pour the heat to it? |
| Back to top |
the tractor vet Tractor Guru
Posted: Sat Jan 19, 2013 5:19 pm Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
Ya must be working on a Dodge ?? When i bought my 95 it was just two year old and the ft. axle U/joints were toast . I spent 3 1/2 hours with a one inch brass drift and a four pound hammer and a can of Zep . beating on it . Fixed the right side and moved to the left and gave up on the four pounder and went to the sledge as some dummy came in and asked if he could give me a hand . So with him holding the drift i was able to lay into it and that one only took and hour . When i put everything back together it was all cleaned up and NEVER SEIZED a few years later i had to get back into it to do the ball joints and wheel bearings ( dumbest design ever ) and guess what it was all froze up and it was back to beating . One guy said all ya had to do is use a scoket and extension and place it so that you just used the power steering to PUSH the bearing out , YEa right that did not work . BUT A 10 pound sledge and a one inch brass drift on the bolts will if you can find some dummy to hold while you swing . |
| Back to top |
ASEguy Tractor Expert
Posted: Sun Jan 20, 2013 4:17 am Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
Don't heat it. Either hit the flange or use a small chisel under the bearing mounting hole as a "wedge" and rotate locations until it walks out. Using the old bolts can work, but they need to be threaded almost all the way in and you would need to use an air chisel gun with a punch so you don't mash the head. You can either go to the dealer to get new one's or I go to a local salvage yard and find a Dodge with them in. Don't just put any bolt in that fits. Gerard |
| Back to top |
D1206 Regular
Posted: Sun Jan 20, 2013 6:53 am Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
I did the wheel bearing on my 2001 2500 couple years ago.Removed it using the socket and power steering method and it worked good...... |
| Back to top |
Broken dodge Guest
Posted: Sun Jan 20, 2013 12:53 pm Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
Got it. A smashed finger, 2 destroyed bolts, and a destroyed dust shield, but its off. Ended up grinding down a chisel to a razor sharp point, and finally got somewhere. |
| Back to top |
caseyc Long Time User
Posted: Tue Jan 22, 2013 2:45 pm Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
I know it's too late but this will be for next time. Take the proper socket for the bolt and add a extension for a total length of 3-4 inches. Thread the bolts in about half way. Put the socket with extension on the bolt head, start the truck up and SLOWLY turn the steering wheel pressing the end of the extension on the axle tube. Work back and forth, switching which bolt your pressing on, basically pressing the hub out. Works every time.
Casey in SD |
| Back to top |
Brian Jasper co. Ia Tractor Expert
Posted: Sun Jan 27, 2013 7:39 pm Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
+1 on Casey's method. Pounding on the bearing or studs just makes for more work. Using the leverage of the P/S pushes them out very quickly and easily. |
| Back to top |
randyc1983 Regular
Posted: Mon Feb 18, 2013 5:52 pm Post subject: Re: Wheel bearing assembly removal on 2001 2500 |
I had that trouble on mine once. Went and bought some long bolts that threaded in. Got the sledge out and smacked those bolts and it popped loose. The longer bolts sure made it easier. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
