MM water pump
Mendontractorguy
PostPosted: Sat Jan 19, 2013 2:57 pm    Post subject: MM water pump Reply to specific post Reply with quote
My '41MM RTI kept over heating. I replaced the radiatorstill overheats. I just took it all apart for total restoration and the water pump is pretty basic, Impellers are moving freely with nothing else to inhibit performance. What else would cause overheating? No thermostat.
old
PostPosted: Sat Jan 19, 2013 6:22 pm    Post subject: Re: MM water pump Reply to specific post Reply with quote
Lack of a thermostat will in fact cause over heating due to the fact the water flows to fast to cool down do it keep getting hotter instead of having time to cool down.
Mendontractorguy
PostPosted: Sun Jan 20, 2013 5:54 am    Post subject: Re: MM water pump Reply to specific post Reply with quote
hen I said 'No Thermostat" I meant I don't see one or anyplace one would have been. This tractor ran fine until just after I bought it from a friend.
old
PostPosted: Sun Jan 20, 2013 8:47 am    Post subject: Re: MM water pump Reply to specific post Reply with quote
Thermostat should be some place in line with the top radiator hose. You could also have a block that is full of rust and lime and needs to be flushed. My self I use white vinegar. Drain the system and fill with vinegar and run it till hot. Let cool and drain then flush with water from a garden hose. Best way is to rig up a way to use the block drain to flush it
Mendontractor guy
PostPosted: Sun Jan 20, 2013 9:03 am    Post subject: Re: MM water pump Reply to specific post Reply with quote
Thanks for the advice. hope to have time tonight to look for that thermostat and will do the flush as you suggest!
glennster
PostPosted: Sun Jan 20, 2013 10:55 am    Post subject: Re: MM water pump Reply to specific post Reply with quote
Check your ignition timing and the mechanical advance. If the timing is running retarded, it will heat up quick. Tocheck the advance, remove distrib cap, grab the rotor and give it a flip. It should move some and then snap back. The works under the breaker plate may be rusted up.
Jon Hagen
PostPosted: Sun Jan 20, 2013 8:04 pm    Post subject: Re: MM water pump Reply to specific post Reply with quote
Some moline models had a thermostat cartridge inside the top radiator hose. A seemingly unnessary hose clamp in the middle of the hose and a hard spot in the hose is a tipoff.
I also agree to look for a stuck distributor advance or retarded ign timing.
Have also seen overheating from a bad water pump seal leaking air into the system.
JK2
PostPosted: Sat Jan 26, 2013 7:29 pm    Post subject: Re: MM water pump Reply to specific post Reply with quote
Two things not mentioned are:
If you do put a new thermostat in the top radiator hose, make sure it has a hole in it to allow some water to go through or it will boil before the thermostat opens. 1/8" hole is fine.
A thermostat for an 8N ford works.
R's and Z's have what is refered to as a BAFFLE (RE521) around the impeller. If it is missing, the engine will sometimes run hot.
Bud Tierney
PostPosted: Wed Jan 30, 2013 1:36 pm    Post subject: Re: MM water pump Reply to specific post Reply with quote
Head gasket beginning to leak can let hot combustion air from one or more cylinders into coolant with no missing or other symptoms (often will run OK with no load on engine but heat under load/going uphill etc...but try all the cheapest/easiest fixes first...
