Author |
Message |
Toby B New User
Posted: Sat Jan 19, 2013 9:02 pm Post subject: 4020 engine surge |
Hello, I"m looking at a 4020 to buy and in speaking to the former owner he told me after it was warmed up and under load it would surge a little. The dealer changed the injector pump but no luck. Any ideas? I hate to buy into a big problem.
Thank you |
Back to top |
Too Far Gone Long Time User
Posted: Sat Jan 19, 2013 9:35 pm Post subject: Re: 4020 engine surge |
We had one years ago that got to doing weird stuff like that and its cam gear was so worn you could move the flywheel like 18 degrees before the timing marks in the injection pump would move.I think its supposed to be like no more than 3 degrees.This tractor also heated after an hour of pulling.New cam gear fixed it all. |
Back to top |
David G Tractor Guru
Posted: Sun Jan 20, 2013 5:10 am Post subject: Re: 4020 engine surge |
It could be the injector pump, or an air leak in the diesel lines going to the pump. |
Back to top |
Jethro Lilley Regular
Posted: Sun Jan 20, 2013 5:43 am Post subject: Re: 4020 engine surge |
try something simple first... change the fuel filters. |
Back to top |
Toby B New User
Posted: Sun Jan 20, 2013 6:56 am Post subject: Re: 4020 engine surge |
Ok, thank you for your help. |
Back to top |
430 Guest
Posted: Sun Jan 20, 2013 10:13 am Post subject: Re: 4020 engine surge |
Was there noise coming from the front of the engine? I think this might be an issue with my 4320. |
Back to top |
Posted: Sun Jan 20, 2013 11:52 am Post subject: Re: 4020 engine surge |
No noise at all,pulled OK,just surged and heated |
Back to top |
