bracing a john deere g pulling motor
sammy G
PostPosted: Sun Jan 20, 2013 10:22 am    Post subject: bracing a john deere g pulling motor Reply to specific post Reply with quote
is there a good way to brace the underside of the frame on the g to support the big 7 3/4 block because u have to grind so much out of the crank case i think its gonna be weak mabey sum tubing or sumthing from the back any ideas?
JohnDeereJimOhio
PostPosted: Sun Jan 20, 2013 10:53 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
I have a piece of flat stock that connects my belly bar to my hitch to support mine.. I'm not running a huge motor but piece of mind if it would fly apart I can send you pics
sammy G
PostPosted: Sun Jan 20, 2013 11:12 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
that would be awesome if ud send me some pics thank u
Little Big B
PostPosted: Sun Jan 20, 2013 11:24 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
sammy G wrote:
(quoted from post at 20:12:54 01/20/13) that would be awesome if ud send me some pics thank u
Hey I know of just the thing you need. Give me a call sometime and I'll get you talking to the right guy on the braces.
Derek Holdren 605 929 2797
View user's profile MSN Messenger
JD PHIL
PostPosted: Sun Jan 20, 2013 1:22 pm    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
I would like to see pic's also somebody post a few.
JohnDeereJimOhio
PostPosted: Sun Jan 20, 2013 5:19 pm    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
This is a pic of my weight bracket and hitch off the tractor.. Other is one on but u can't see it as well..
Unstyled G Guy
PostPosted: Mon Jan 21, 2013 9:14 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
If your going to go 7-3/4" block then it would be best to have a machine shop cut out the crankcase. We've done 2 crankcases for that size block in our machine shop on a mill and the wall's are THIN, even with the patches. I would also suggest that you wait until you actually get the block before having the crankcase bored... I know people are waiting on these blocks but have only seen one actually show up.
sammy G
PostPosted: Mon Jan 21, 2013 12:51 pm    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
can it be milled out on the tractor of will it have to be stood up right?
Unsettled G Guy
PostPosted: Mon Jan 21, 2013 1:21 pm    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
Crankcase has to be taken out, meaning rearend and front end have to be taken off so that just the crankcase goes on the mill. Also better if you take tranny out. If you haven't split/broke down a John deere G that much before it could seem like a big ordeal but it really isn't that hard and doesn't take that long
GoJDpuller
PostPosted: Tue Jan 22, 2013 6:41 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
I thought they make these blocks longer so you keep the sleeves out of the case
GoJDpuller
PostPosted: Tue Jan 22, 2013 6:48 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
GoJDpuller
PostPosted: Tue Jan 22, 2013 10:19 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
sammy G
PostPosted: Tue Jan 22, 2013 11:04 am    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
no thats and 8 in from extreme murphys sleves go in the crank case
FactoryFarmer
PostPosted: Tue Feb 05, 2013 3:30 pm    Post subject: Re: bracing a john deere g pulling motor Reply to specific post Reply with quote
Heres mine
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
