| Author |
Message |
JeffWfarm New User
Posted: Sun Jan 20, 2013 1:18 pm Post subject: Air Compressor Identity |
I found this in my barn. Plugged it in and it works, but the pump needs work, slow to fill tank. Any idea WHAT it is?
| Back to top |
GarryinNC Regular
Joined: 04 Mar 2008 Posts: 148 Location: Davie County,NC
Posted: Sun Jan 20, 2013 1:35 pm Post subject: Re: Air Compressor Identity |
Looks likes it was made from an old refrigeration compressing unit. It may never pump real fast, looks like it has small pistons. |
| Back to top |
MisterT Long Time User
Posted: Sun Jan 20, 2013 1:39 pm Post subject: Re: Air Compressor Identity |
Was that barn ever used for a dairy operation? It might be a vacuum pump for the milkers. |
| Back to top |
XRogerX Regular
Posted: Sun Jan 20, 2013 1:46 pm Post subject: Re: Air Compressor Identity |
Might be Brunner, but it looks like a home-built lash-up to me. I agree that it looks like a re-purposed reefer compressor, as it has no cooling fins. I wouldn"t trust that tank. |
| Back to top |
KSTractor Regular
Posted: Sun Jan 20, 2013 2:03 pm Post subject: Re: Air Compressor Identity |
Pre OSHA when people were smart enough to keep fingers out of belt and fan |
| Back to top |
JeffWfarm New User
Posted: Sun Jan 20, 2013 2:29 pm Post subject: Re: Air Compressor Identity |
| MisterT wrote: | (quoted from post at 22:39:24 01/20/13)
Yes it was a dairy farm. Thanks for the reply |
| Back to top |
JeffWfarm New User
Posted: Sun Jan 20, 2013 2:30 pm Post subject: Re: Air Compressor Identity |
So maybe my best best would be to sell it for parts and get a real compressor? |
| Back to top |
Posted: Sun Jan 20, 2013 2:56 pm Post subject: Re: Air Compressor Identity |
| JeffWfarm wrote: | (quoted from post at 23:30:06 01/20/13)
Remove the electric motor and maybe a few other parts, save those for future use, and then send the rest of it to the scrap pile. |
| Back to top |
Glenn F. Guest
Posted: Sun Jan 20, 2013 8:09 pm Post subject: Re: Air Compressor Identity |
UI wouldn't be too quick to scrap it. The old compressors are the good ones. Make sure you have all leaks stopped. Use it awhile. It may improve. It'll probably never be too fast, but if it just doesn't seem to be performing, remove the head & have a look at the reed valves. I like old compreseors.
Glenn |
| Back to top |
Russ from MN Tractor Expert
Posted: Sun Jan 20, 2013 8:32 pm Post subject: Re: Air Compressor Identity |
I helped a co-worker test run one of those once, I think it built up over 300 psi,(without a tank) make sure you have a good relief valve on it. |
| Back to top |
Ken Macfarlane Tractor Expert
Posted: Mon Jan 21, 2013 8:09 am Post subject: Re: Air Compressor Identity |
Again, old refer pump. See how the air comes up through the
crankcase inlet? There's a valve in the piston to let it in the
cylinder.
I wouldn't run that sucker up with that tank! |
| Back to top |
JMOR Tractor Guru
Posted: Mon Jan 21, 2013 8:24 am Post subject: Re: Air Compressor Identity |
| XRogerX wrote: | | (quoted from post at 17:46:00 01/20/13) Might be Brunner, but it looks like a home-built lash-up to me. I agree that it looks like a re-purposed reefer compressor, as it has no cooling fins. I wouldn"t trust that tank. | Bet you are too late, as he already ran pressure up.........see outlet gauge. |
| Back to top |
PJH Tractor Expert
Posted: Tue Jan 22, 2013 10:54 am Post subject: Re: Air Compressor Identity |
Spin it around so the belt is next the wall. Then you're less apt to get your shirt tail wrapped up in it. |
| Back to top |
