Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall 450
Goto page 1, 2  Next
Bud Kaiser
PostPosted: Sun Jan 20, 2013 8:18 pm    Post subject: Farmall 450 Reply to specific post Reply with quote
Does anyone know of a place to get rod bushings for my 450. I could only find them at Case IH but 76$ a piece seems high.
Huskers86
PostPosted: Sun Jan 20, 2013 8:50 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Bud Kaiser wrote:
(quoted from post at 21:18:59 01/20/13) Does anyone know of a place to get rod bushings for my 450. I could only find them at Case IH but 76$ a piece seems high.
I don't know if this site sell them or not but try agkits.com...they have them from $5 to $10.
d beatty
PostPosted: Sun Jan 20, 2013 8:59 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Try Bates Corporation Boubon, IN. Theirs start out at $17.00 up to $100.00 depending on what size you need.
Bud Kaiser
PostPosted: Sun Jan 20, 2013 9:51 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Bates wants 96$ a bushing.This seems un reasonable anybody else have any ideas. Machine shop said they could make some out of brass.These would not be like stock, they have metal where they contact the rods, They said this should be okay.What do yall think? I may have to for 20$ a piece, cannot see paying as much for the bushing as I did for the overhaul kit.
D Slater
PostPosted: Mon Jan 21, 2013 5:30 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Can't believe they are that high now. After checking I see them from $58.?? to a $160 plus each.
Can still get the bushings for the C-264 engines before they changed the C-264 to the same rods as a C-281 for $10 to $15 or a little less. Also you can get the adapter bushings to put in previous rods to use the C-281 piston pin size in older rods for a little less than than the 450 bushing. And I thought they had got way to high. Both those bushings are bigger than a 364921r1 bushing. Think someone in the supply chain is taking us to the cleaners.
YT has reconditioned small pin C264 and 281 connecting rods listed for $146.?? and just the bushing for $112.??.
Chester5731
PostPosted: Mon Jan 21, 2013 6:29 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
I did have a set laying around for my super M but I don't know what diameter they are. They were from tisco about 20 years ago. I can check and see what they are and let you know.
Greg Lussetto
PostPosted: Mon Jan 21, 2013 7:14 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Vollbrachts in Columbus, NE has them much cheaper. 402-564-5993
Greg
Janicholson
PostPosted: Mon Jan 21, 2013 1:06 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Brass is a common pin bushing material. The clearance is way tight, so a pin fitting machine using a hone is best practice. most are fit to .0005 to .0008" looser and it will make noise. Jim
Huskers86
PostPosted: Mon Jan 21, 2013 7:01 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
I'll speak up so you can hear me. AGKITS.COM $5 to $10 each. I've ordered stuff there and have had no complaints.
Huskers86
PostPosted: Mon Jan 21, 2013 7:10 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
I'll even give the part number 364913 and are $4.99 each.
D Slater
PostPosted: Mon Jan 21, 2013 8:59 pm    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
364913 won't work, to small. 450 uses # 364921R1. I couldn't find 364921R1 on that site.
Huskers86
PostPosted: Tue Jan 22, 2013 6:54 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
D Slater wrote:
(quoted from post at 21:59:43 01/21/13) 364913 won't work, to small. 450 uses # 364921R1. I couldn't find 364921R1 on that site.
It states the 364913 is for the c281 and others, this is agkits part number. Is the 364921R1 a farmall number?
D Slater
PostPosted: Tue Jan 22, 2013 7:12 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
364913 is a IH number also, agkits just left the R1 off. That bushing is for 6 cylinder engines like used in some 460, 560 and others.
Not sure, but think agkits should have put 282 in the listing instead of 281.
Huskers86
PostPosted: Tue Jan 22, 2013 7:46 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
D Slater wrote:
(quoted from post at 08:12:45 01/22/13) 364913 is a IH number also, agkits just left the R1 off. That bushing is for 6 cylinder engines like used in some 460, 560 and others.
I see, I have a 450 gas that I'll be overhauling some day so I'm trying to figure this out so I can get the right ones when I order parts. On my 460 I had to hone out a little bit on the rods to get the proper fit. I think this is pretty common but I have not done a lot of them.
Chester5731
PostPosted: Tue Jan 22, 2013 9:07 am    Post subject: Re: Farmall 450 Reply to specific post Reply with quote
Last night I found the ones I have. They are tisco # 45748-dar and they have clevite 01251 stamped in them. I don't know if they would fit a 450 or not.
Goto page 1, 2  Next
Page 1 of 2
