| Author |
Message |
John 37A Regular
Joined: 16 Jun 2010 Posts: 215 Location: Somerset, OH
Posted: Mon Jan 21, 2013 3:22 pm Post subject: Ignition and wiring questions |
I am working on a 52 A and am down to spark and wiring. The tractor has been converted to 12 volt, but how can I tell if it is positive ground or negative? I hooked it up with + ground and it spun the engine over, but I had no spark.
I would like to switch to electronic ignition, and if I do, assuming it is + ground, what all is effected? Ammeter wires need switched and generator needs polarity switched? Anything else?
Thanks,
John |
| Back to top |
Maark Guest
Posted: Mon Jan 21, 2013 4:04 pm Post subject: Re: Ignition and wiring questions |
Does it have a alternator? Most are negative ground. Check the wire from the coil to the distributor. It should be the same as the ground on the tractor. |
| Back to top |
John 37A Regular
Posted: Mon Jan 21, 2013 4:10 pm Post subject: Re: Ignition and wiring questions |
No it's still a generator. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
