| Author |
Message |
david1 Guest
Posted: Mon Jan 21, 2013 6:04 pm Post subject: Sealing up a NH 55 gearbox |
Been working on this gear box and now putting it back together. Whats the best way to seal up the back plate that has all the bolts around it. Does NH sell a gasket or is it best to use liquid gasket sealer? I put a new seal on the in put shaft, would really like to run 90 w gear oil and not have to fill it with cornhead grease as that what was in it but that is a pain if you have to open it up to work on it. Am I expecting too much hoping that a new seal on the input shaft won't leak the 90 weight oil. Thanks |
| Back to top |
Bob Bancroft Tractor Expert
Posted: Mon Jan 21, 2013 6:08 pm Post subject: Re: Sealing up a NH 55 gearbox |
I worked at a NH dealer in the 70's. NH told us to pump two tubes of grease in them way back then. If I were doing one now I would use corn head grease. |
| Back to top |
paul Tractor Guru
Posted: Mon Jan 21, 2013 7:41 pm Post subject: Re: Sealing up a NH 55 gearbox |
Corn head grease.
You're expecting too much.
Paul |
| Back to top |
Erik Ks farmer Tractor Expert
Posted: Mon Jan 21, 2013 7:46 pm Post subject: Re: Sealing up a NH 55 gearbox |
pump full of cornhead grease, I ran one for several years. Even if you reseal it's going to leak 20 acres later. BTDT |
| Back to top |
Formerly PaMike Long Time User
Posted: Tue Jan 22, 2013 2:35 am Post subject: Re: Sealing up a NH 55 gearbox |
I rebuilt mine the other year. Yes, there is a gasket. I filled mine with oil, no problem to date... |
| Back to top |
tomstractorsandtoys1 Long Time User
Posted: Tue Jan 22, 2013 7:47 am Post subject: Re: Sealing up a NH 55 gearbox |
Something else to consider is to use John Deere Multi-lube,it is a pourable grease than was used in built on lube systems of cornpickers,balers and older combine cornheads.On our Deere 660 rake the manual says to fill with grease and if you rebuilt it you should not ever have to work on it again. |
| Back to top |
onefarmer Tractor Expert
Joined: 14 Jan 2005 Posts: 2352 Location: St. Johns Mi
Posted: Tue Jan 22, 2013 8:02 am Post subject: Re: Sealing up a NH 55 gearbox |
About 10 years ago I rebuilt the box on my NH55. I sealed the back plate with blue permatex and filled the box with a tube of regular gun grease and a pint of 80/90. It's still going. |
| Back to top |
RodinNS Tractor Guru
Posted: Tue Jan 22, 2013 9:26 am Post subject: Re: Sealing up a NH 55 gearbox |
I've seen some that had nothing but a grease nipple on them...
You can use silicon on the plate... as far as I know.
I'd still expect it's probably going to leak on the shaft tho.
Rod |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
