| Author |
Message |
SmokeShow Guest
Posted: Mon Jan 21, 2013 7:58 pm Post subject: JD 455 engine problems |
I have a 455 diesel that has what I think a sticking injector. It smokes a lot of black smoke and has no power what so ever. It starts and idles fine but will bog down under a load. The tractor has 700hrs. Has anyone out there run in to this problem? From what I read the Yanmars are good engines. |
| Back to top |
504 Tractor Expert
Posted: Mon Jan 21, 2013 9:18 pm Post subject: Re: JD 455 engine problems |
Check both air filters(inner & outer) and change the fuel filter. That just may take care of it. |
| Back to top |
Traditional Farmer Tractor Expert
Posted: Tue Jan 22, 2013 6:04 pm Post subject: Re: JD 455 engine problems |
As said new air filters and check to make sure there is no water in the fuel at 700 hrs that engine is just broken in good |
| Back to top |
SmokeShow Guest
Posted: Tue Jan 22, 2013 7:08 pm Post subject: Re: JD 455 engine problems |
This mower is brand new to me. I just changed the air filter and runs alot better. Thank You. I do have another question on the bottom of the air filter canister should there be something over the air inlet? |
| Back to top |
G1355 Long Time User
Posted: Tue Jan 22, 2013 7:56 pm Post subject: Re: JD 455 engine problems |
There should be a rubber "nipple", that's what our f935 has, same motor |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
