| Author |
Message |
RalphWD45 Long Time User
Posted: Mon Jan 21, 2013 9:12 pm Post subject: Rebuild kit for 335 mnpls moline |
Hi guys! I need to get a rebuild kit for a TSX carb and the numbers on my ID plate don't add up with anything on YT's parts. I googled Tsx ID numbers, and ended up at a site that listed several pages, of numbers, but still couldn't match it up. I am going to attempt to put the numbers on this post, hopefully in an understandable way! The plate is riveted on, and the #62 is on the left side of the rivet, and the #0 is alone on the right side of the rivit. Below that line is tsxu, as the second line down.Then below that is 834 which makes the third line. can anyone tell me where to get this kit? I also need a new float, but YT has one available, that looks the same. |
| Back to top |
shinnery Long Time User
Joined: 18 Apr 2006 Posts: 974 Location: Hawley, Texas
Posted: Mon Jan 21, 2013 10:38 pm Post subject: Re: Rebuild kit for 335 mnpls moline |
I would contact Matt at MOTEC Eng. & Restoration 765 9six3 6623. 7342 W St. Rd. 28 Tipton, IN 46072 for any carb related parts.
Bryce |
| Back to top |
Paul in MN Long Time User
Posted: Tue Jan 22, 2013 10:25 am Post subject: Re: Rebuild kit for 335 mnpls moline |
The 62 is probably a date of manufacturing code, the year it was made.
The TSX 834 or TSXU 834 is what you are looking for.
Totally a guess.. This is a small cubic inch engine, and its MS carb is probably compatable with the Ford 8N. Not a direct trade because of a different orientation and the linkage rods maybe being on the opposite side. But it probably takes the same gasket and renewal kit.
I have found many smaller tractors to use the same kit. Try NAPA #2-1401 or Walker #778-505 (from O' Reilly's). The kits will have lots of parts that you do not need, but they are packaged so that one kit fits dozens of applications.
20 years ago I had a 335, but do not now have its parts data.
Paul in MN |
| Back to top |
Posted: Tue Jan 22, 2013 11:07 am Post subject: Re: Rebuild kit for 335 mnpls moline |
Thanks guys! Between the two of you , I belive I have enough info to be effective. Now I know enough to ask intellegently, for the kit. The carb has been soaked in cleaner, and all passages rodded out, and is ready for reassembly. the float had gas in it, and was somewhat caved in, Ill go ahead and order the float from YT, and see what I can get at the auto parts locally., if not then I will call the folks that shinnery spoke of, and lay it in their hands. |
| Back to top |
chad-sd New User
Posted: Tue Jan 22, 2013 5:29 pm Post subject: Re: Rebuild kit for 335 mnpls moline |
i bought one 6 month ago for my 335 moline at advanced auto parts worked great. part number was 96-448 Gp Sorensen was the brand. I think you can get them at auto Zone to, had to specal order. hope it helps. |
| Back to top |
t.r.k. Guest
Posted: Tue Jan 22, 2013 5:50 pm Post subject: Re: Rebuild kit for 335 mnpls moline |
Napa kit 1403. No throttle shaft in it, though.
I think external link Parts has the floats.
Sometimes I see the small one hanging on the wall at Tractor Supply. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
