Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
201 gas vs diesel
Post new topic    Yesterday's Tractors Forum Index -> Ford
Ultradog MN
PostPosted: Tue Jan 22, 2013 5:38 am    Post subject: 201 gas vs diesel Reply to specific post Reply with quote
Were the gassers subject to the same cavitation/porosity problems as the diesels were?
I've read lots of posts about cavitation in diesels but never once about it in a gasser.
Kenny just found out he has the dreaded cylinder wall rust-through on that junky 4600 he's working on.
We were thinking it would be cheaper to use a gas block that I have rather than the expense of having it sleeved.
Fordfarmer
PostPosted: Tue Jan 22, 2013 6:17 am    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
AFAIK, the problem is more common in diesels, but the gassers aren't immune. If I understand it right, its more common in the diesels because of the higher combustion pressures, which result in more cylinder wall flex and the resulting cavitation. Using your gasser block will be cheaper IF it doesn't need to be bored out, but beyond that, you won't gain anything.
Texasmark1
PostPosted: Tue Jan 22, 2013 6:28 am    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
Don't remember the color, but once I was reading parts lists on tractors and noticed that the bottom end of diesel's was a lot heftier than gas counter parts. One difference I recall is a main for each cylinder whereas the gas only had 3 for the whole engine.
HTH,
Mark
Dean
PostPosted: Tue Jan 22, 2013 6:31 am    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
AFIK, there is no cavitation issue with the gasoline engines.
Dean
RodinNS
PostPosted: Tue Jan 22, 2013 7:10 am    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
I'd check the parts book and make sure the blocks are identical. I think they are... but check.
Rod
Paul in MN
PostPosted: Tue Jan 22, 2013 9:58 am    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
I've paid mild attention to this topic for a number of years as I have 3 401 6 cylinder diesels plus Ford Powerstroke PU engines (none of which have showed this problem). The industry sources say the cavitation is due to the high level of diesel "ping" as it fires under load. This ping sets up the coolant touching the cylinder side into small bubbles. As the bubbles burst, the coolant slams back into the void and slams the cylinder sidewall hard enough to create the erosion. In the Powerstroke engines this can be greately reduced by using the Ford coolant additive. I think it acts like a soap keeping the coolant "wetter". Ford formulated a yellow color antifreeze with the same properties, so it does not need the additive. This same type of cavitation occurs in other brand tractor and truck diesel engines and is dealt with in a variety of methods.
Our gasoline engines have never had any significant problem with these issues, as their combustion is more of a "woosh" than a "bang". Antifreeze formulated for big truck engines is a different chemistry than normal auto antifreeze. It does not have the silicates that auto antifreeze has.
As to the interchangability of the gasser block and the diesel block, I have no real knowledge, but I'd sure have my doubts.
Paul in MN
souNdguy
PostPosted: Tue Jan 22, 2013 12:15 pm    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
i've also hear leass/no issue with gassers.. however I still run the DCA addatives in my gassers.
Jerry/MT
PostPosted: Tue Jan 22, 2013 12:58 pm    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
The initial combustion pressure rise due to compression ignition is more like "knock" in a gas engine and so that"s why the problem occurs.
Ultradog MN
PostPosted: Wed Jan 23, 2013 7:30 pm    Post subject: Re: 201 gas vs diesel Reply to specific post Reply with quote
Thanks fellows.
I think he's going to bore and sleeve the block he has. Mainly because the block I have is the old style with the screw in plugs.
Means he'd have to go back to a generator to run the tach.
I have a set of NOS sleeves he's going to use.
I also have an NOS 4600 head he's going to take.
Going to trade me for his old head.
Such a deal.
I think I'll go to bed now and cry.
