| Author |
Message |
jbeicker New User
Posted: Tue Jan 22, 2013 6:38 am Post subject: 1175 3 point |
I am having an issue with the 3 point on the tractor. It will raise fine but doesn"t want to go down without weight on it. Sometime i can get it to go down just by standing on it. Other time i have to use the front end loader on the other tractor to push it down. Is this a stuck or sticking check valve that would be causing this?
Thanks for the help. |
| Back to top |
Agri King Long Time User
Posted: Wed Jan 23, 2013 4:25 am Post subject: Re: 1175 3 point |
I would bet the 3 pt. hasn't been used very much and the piston is sticky. Useing a bale mover or semi mount plow etc. for a day or so should help. |
| Back to top |
1031D Tractor Expert
Joined: 31 Jul 2004 Posts: 1746 Location: Southern Wisconsin
Posted: Wed Jan 23, 2013 5:54 am Post subject: Re: 1175 3 point |
My 1030 was the same. Milky oil seemed to be the culprit. Took a weekend of plowing and she's been fine since. It was so bad I bought a 3pt drawbar to jump on to get it down! |
| Back to top |
jbeicker New User
Posted: Wed Jan 23, 2013 8:25 am Post subject: Re: 1175 3 point |
Sounds good. I will get some weight back there and try to get some use on it. |
| Back to top |
Brokengun Long Time User
Posted: Wed Jan 23, 2013 9:39 am Post subject: Re: 1175 3 point |
I had that happen to one of my 930CK. I almost never use the tractor 3PT.
It ended up being a small amount of rust on the lower part of the 3PT cylinder.
I agree with others it should clear up once you start using it |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
