Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
4430 quad range linkage?
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> John Deere
Chris95
PostPosted: Tue Jan 22, 2013 1:16 pm    Post subject: 4430 quad range linkage? Reply to specific post Reply with quote
Just bought this tractor and the dealer put new sychronizers on both the range and speed gears. It still jumps out of gear from time to time in B range. It wont stay in C at all. The shifter feels loose. Is there a spring that is supposed to provide resistance to the lever going side to side? When I shift to C range the lever will basically fall into tow. I am new to a QR and was wondering what holds it in gear?
Tx Jim
PostPosted: Tue Jan 22, 2013 1:36 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Worn out cab mounts can cause shifting problems. Detent ball(parts key #23) help hold shift drum in place
Tech 7
PostPosted: Tue Jan 22, 2013 1:49 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
I will add to what TxJim said..make sure that shaft (key #11) has minimal endplay. Endplay is removed by changing the position of arm (17) on the shaft.
Chris95
PostPosted: Tue Jan 22, 2013 2:02 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Can I put a larger spring in to apply more force to the detent ball?
Tx Jim
PostPosted: Tue Jan 22, 2013 2:48 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
The holes can get worn in parts # 21 causing the ball not to hold very well. If I were you I would be having a real serious talk with the dealership that the tractor was purchased from.
tim s
PostPosted: Tue Jan 22, 2013 3:47 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
What year is it?? The picture Jim is showing is not for the ranges, it's the bottom one that needs attention, with the same regards to the detent stuff, but the newer ones had a spring that went from the lower shift link to the cab to give a bit of counter balance to the heavy shift lever, and be sure the shifter is lined up with the shift plate in the cab.I'm wondering if who ever went into the transmission should have went on down and re-built the bottom shaft too????
Chris95
PostPosted: Tue Jan 22, 2013 3:53 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Yeah it seems like if it where that worn they should have replaced it
while it was tore apart.
I got the tractor home chisel plowed for about an hour and told
them to come get it. Two months later it they brought it back
staying in gear much better but it is still not right.
Chris95
PostPosted: Tue Jan 22, 2013 4:01 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
1974
tim s
PostPosted: Tue Jan 22, 2013 4:59 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Thats an early one then, in mid 1975 they made a lot of good changes in the 4430's, that model did not come with the spring I was talking about but you could put one on it..
Chris95
PostPosted: Tue Jan 22, 2013 5:14 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
I will try the spring. I am going to call the service manager tomorrow to ask about the detent parts being replaced. I would think they would have which makes me think it is more of an adjustment thing. There is an adjustment for the lever to the shift plate in the console?
tim s
PostPosted: Tue Jan 22, 2013 6:09 pm    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
The linkage adjustment is a turn buckle on the shift rod, to get it right you need to feel it in gear then adjust the rod to where it matches up with the shift plate, but the shift plate is for placement not to hold it in gear.
Tx Jim
PostPosted: Wed Jan 23, 2013 3:56 am    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
I'll try again. Sorry for the incorrect photo but it's been many tears since I looked inside a QR trans.
tim s
PostPosted: Wed Jan 23, 2013 4:02 am    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Don't beat yourself up Jim,,I've been into 3 this month, and one waiting to come in...I know linkage "can" be the problem some times with these not staying in the ranges,,,but "most" of the time it's some thing going on with the bottom shaft area,worn snap ring grooves, worn shift collars/gears,end play issues, and such...but you need to prove the "on top" stuff first...
Tx Jim
PostPosted: Wed Jan 23, 2013 4:23 am    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
Tim
After you stated incorrect photo I thought to myself " what was I thinking" as that drum shifter goes on a syncronizer and not associated with A-B-C-D.
tim s
PostPosted: Wed Jan 23, 2013 4:31 am    Post subject: Re: 4430 quad range linkage? Reply to specific post Reply with quote
You have been doing good at posting the break down pics,,I have been up to my neck with transmissions lately, so I'm staying "fresh" on them....got a 4020 down now for a top shaft re-build..will be going back together with it today..
Goto page 1, 2  Next
Page 1 of 2
