| Author |
Message |
IrvIA Regular
Posted: Tue Jan 22, 2013 3:17 pm Post subject: FORD |
I've got a Ford garden tractor I've had for 5 years, and today I found the serial plate actually had numbers on it. Digital cameras are amazing. I thought they were all rubbed off. Can anyone decipher this? It's a 10hp Kohler, with a hydro. What model have I got? I'm looking for a hood.
Thanks, Irv
| Back to top |
G1355 Long Time User
Posted: Tue Jan 22, 2013 4:04 pm Post subject: Re: FORD |
I'd say its a 125 or 145 could be wrong. And my guess would be a 12 or 14hp kohler |
| Back to top |
Harvey 2 Regular
Posted: Tue Jan 22, 2013 4:17 pm Post subject: Re: FORD |
I have a complete 145 Ford I would sell for about what a hood would cost you.
Where are you located ? |
| Back to top |
Maineman Regular
Posted: Tue Jan 22, 2013 4:44 pm Post subject: Re: FORD |
Your picture is of an early seventies Ford by Jacobsen.
It would be an LGT 100, 125, 145 or an LGT 165.
Depending on the engine horse power.
If it has a ten horse it should have a gear drive not a hydro.
Ford used the same model designation on the next model
Tractors from the late seventies. Yours is an open side model.
The later ones are referred to as closed side models.
All open side LGT"s used the same hood.
Unfortunately, whoever added those numbers to the data plate did not get the right. The O9JC number would be for the mower deck.
The model number should have been 32XX.
Those are great tractors. I have two. It"s worth getting a hood.
Joe |
| Back to top |
Patrick Klise Regular
Posted: Tue Jan 22, 2013 6:07 pm Post subject: Re: FORD |
If it"s got a 10hp Kohler--then its the LGT100. I"ve got one. Don"t think they made them with a hydro transmission though. There is a Ford/Jacobsen group on Yahoo that has lots of Ford enthusiasts that can help out. Hope this helps. |
| Back to top |
Brian G. NY Tractor Expert
Posted: Tue Jan 22, 2013 8:43 pm Post subject: Re: FORD |
I concur with Joe.
The only number that tells me anything is the Engine number. The first two digits tell me its a 1972 model but not the engine size. It could be a 10 HP engine but, if it is original to the tractor it will be a 12, 14 or 16 HP as the LGT-100 (10 HP version) was not available with hydro. Unless you can find some remnants of a designation on the shroud, I don't know of any easy way of positively determining the HP of the engine. There should be a decal located on the air cooling shroud either on the carburetor side at about the level of the points cover or on the flywheel side near the top. The designations are as follows: K241=10HP, K301=12HP, K321=14HP and K341=16HP. The model number is cast into the block but is not visible without removing the electric PTO clutch. These are wonderful little tractors and I have 10HP, 12HP and 14HP open side versions as well as two 16HP closed side versions. Only the LGT-125 is currently running. I have the engines for a 14HP and a 16HP bored over size with everything I need to completely rebuild them except the gumption.
Good mower decks are becoming difficult to find for these machines. I have a 48" blade on my LGT-125 and it can push a lot of snow for a machine of its size!
| Back to top |
Posted: Tue Jan 22, 2013 8:48 pm Post subject: Re: FORD |
BTW, if that grill has no serious cracks, it is quite unusual and will contribute handsomely to the looks of a restoration. |
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 10:26 am Post subject: Re: FORD |
I'm in southcentral Iowa...Oskaloosa |
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 10:32 am Post subject: Re: FORD |
What do you mean by "unusual" on the grill? Isn't it like the one you have?
Irv |
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 11:14 am Post subject: Re: FORD |
Here's the grill.
Irv
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 11:19 am Post subject: Re: FORD |
I tried to join that group at your suggestion and had to go though so many hoops to get there I got lost and finally just gave up. I guess I'm not the most computer savvy.
Irv |
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 11:46 am Post subject: Re: FORD |
Do you mean the 32xx is the model number for the deck? |
| Back to top |
Posted: Wed Jan 23, 2013 12:34 pm Post subject: Re: FORD |
LOL.....I guess I didn't clearly say what I really meant.
What I meant was that many of them wind up being smashed and patched up with sheet metal and screws and look pretty ugly.
Yours looks very nice, by the way!
I would say your tractor looks to be worth repairing even if you did not want to take on a total restoration.
Were you able to find any remnant of a model number on the engine? |
| Back to top |
Maineman Regular
Posted: Wed Jan 23, 2013 2:22 pm Post subject: Re: FORD |
| IrvIA wrote: | | (quoted from post at 12:46:08 01/23/13) Do you mean the 32xx is the model number for the deck? |
No, O9JC... Is the model number for the deck. As a separate attachment,
They got different numbers and manuals.
The model number for the tractor should start with 32 and have a total of four numbers.
Do you have a deck?
The grill is not unusual, it's the same for all open sided LGT's
To have one in good condition is unusual.
Joe |
| Back to top |
IrvIA Regular
Posted: Wed Jan 23, 2013 3:40 pm Post subject: Re: FORD |
Oh, I see about the grill. Yea, its really not a bad old tractor. The engine number is all there, I just neglected to put it on here. It's a KOHLER 241AS, SPEC# 466740, SERIAL # 5002707.
I have the deck but the spindle housings are in pretty bad shape, inside and out. I have a lathe and could probably line the bores but that's a bunch of work. Haven't really looked for replacements yet. Just wanted to see if I could find a (inexpensive) hood. |
| Back to top |
