| Author |
Message |
2-banger Long Time User
Posted: Tue Jan 22, 2013 5:33 pm Post subject: dual ex on g |
building a..g thinking about having 2 flanges machined to bolt to hd and having exhaust shop bend 2 pipes to make dual ex...any one ever try this on a g...must give it diff sound..around here either your stock or your pulling in open class..so theres no rules saying i cant do it |
| Back to top |
dboll Guest
Posted: Tue Jan 22, 2013 6:15 pm Post subject: Re: dual ex on g |
my bet is that it will hurt performance, whereas a single pipe uses the ex pulses to induce a draft to help ex flow from each cylinder, a friend of mine went to a pretty small pipe on a good sized A and had to richen the carb. significantly |
| Back to top |
FactoryFarmer Long Time User
Posted: Tue Jan 22, 2013 6:21 pm Post subject: Re: dual ex on g |
| dboll wrote: | | (quoted from post at 19:15:14 01/22/13) my bet is that it will hurt performance, whereas a single pipe uses the ex pulses to induce a draft to help ex flow from each cylinder, a friend of mine went to a pretty small pipe on a good sized A and had to richen the carb. significantly |
I did it to mine, and this G has it done to it as well......far from hurting performance....
http://www.youtube.com/watch?v=iS7kiIvp0ws |
| Back to top |
Posted: Tue Jan 22, 2013 6:26 pm Post subject: Re: dual ex on g |
very nice..i think thats probaly bigger than mine will be..lol..is this the g with turbo on it? |
| Back to top |
Posted: Tue Jan 22, 2013 6:36 pm Post subject: Re: dual ex on g |
No it's NA, 640 cubes |
| Back to top |
Posted: Tue Jan 22, 2013 6:47 pm Post subject: Re: dual ex on g |
ok..u turn alot on rpms..i have some questions if you have time email me |
| Back to top |
Posted: Tue Jan 22, 2013 7:04 pm Post subject: Re: dual ex on g |
| 2-banger wrote: | | (quoted from post at 19:47:30 01/22/13) ok..u turn alot on rpms..i have some questions if you have time email me |
delhotalfarms@gmail.com |
| Back to top |
HollywoodYearwood Regular
Posted: Tue Jan 22, 2013 7:51 pm Post subject: Re: dual ex on g |
It can be done! Ive got the only one around ga, sc with one. Want to stir up some old men, show up with a set. Haha
Untitled URL Link
| Back to top |
JDGnut Tractor Expert
Posted: Tue Jan 22, 2013 9:27 pm Post subject: Re: dual ex on g |
This was a pretty crude setup I built about 17-18 yrs ago... Used a 70 carb.. the right side used a factory shaped exhaust pipe.. but made out of Aluminized pipe..
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23627 Location: in front of computer
Posted: Wed Jan 23, 2013 5:58 am Post subject: Re: dual ex on g |
you can be assured that the factory cast manifold does not use exhaust tuning like a two or four stroke tubular exhaust system.
Deere ran a two into one exhaust on the 80/820/830/840 to improve exhaust flow compared to the 70/720/730. |
| Back to top |
RHBrown New User
Posted: Wed Jan 23, 2013 6:48 am Post subject: Re: dual ex on g |
It has been done. Uncle Buck, whom I had the pleasure of knowing, ran one of the hottest Gs you would ever want to watch. Not only did he have dual exhast he had dual carbs also. You can watch him on youtube. Unfortunetly he passed on this winter he will be sorely missed... |
| Back to top |
Posted: Wed Jan 23, 2013 7:30 am Post subject: Re: dual ex on g |
yea ive seen his g pull here at ny expo runs good |
| Back to top |
2-lunger Guest
Posted: Wed Jan 23, 2013 9:55 am Post subject: Re: dual ex on g |
I made some for my G out of 2 1/2inch alluminized tubing and run a 730 carb, sounds great and pulls great. makes good power dont know if its because of the manifold becuase I never tried a stock one. |
| Back to top |
Posted: Wed Jan 23, 2013 10:57 am Post subject: Re: dual ex on g |
| RHBrown wrote: | | (quoted from post at 07:48:12 01/23/13) It has been done. Uncle Buck, whom I had the pleasure of knowing, ran one of the hottest Gs you would ever want to watch. Not only did he have dual exhast he had dual carbs also. You can watch him on youtube. Unfortunetly he passed on this winter he will be sorely missed... |
Do you know what he was using for carbs? |
| Back to top |
Sammy G Guest
Posted: Wed Jan 23, 2013 12:32 pm Post subject: Re: dual ex on g |
Unckel buck did not have duell exhaust only duell 51 carbs I no Robbie well! |
| Back to top |
