| Author |
Message |
SuperSam New User
Posted: Tue Jan 22, 2013 7:09 pm Post subject: 730 series loader hydraulic fluid capacity |
It's time to change the filter and fluid in my 730 series loader. It's mounted on a 1968, gas, 3400 industrial with a crank driven pump. Can anyone help with info regarding how much fluid I will need. I'm told the filter is an E6NN9R500DA, but not sure of the fluid capacity. The frame assembly is listed as a 19-512. Any help with be appreciated. |
| Back to top |
RickB Tractor Guru
Posted: Wed Jan 23, 2013 2:45 am Post subject: Re: 730 series loader hydraulic fluid capacity |
That number sounds to me like an air filter.
The 12" paper filter is 86546604 and comes with the base gasket. The 9" composite filter is 290417 and the 290397 gasket is sold separately. The paper filter is probably what you have. 730 system capacity is listed @ 10.5 gallons, but unless you purge all the cylinders you won't need much more than 5 or 6. Full level is 12" below the fill/breather cap. |
| Back to top |
SuperSam New User
Posted: Wed Jan 23, 2013 4:22 pm Post subject: Re: 730 series loader hydraulic fluid capacity |
[quote="RickB"](quoted from post at 04:45:04 01/23/13) That number sounds to me like an air filter.
The 12" paper filter is 86546604 and comes with the base gasket. The 9" composite filter is 290417 and the 290397 gasket is sold separately. The paper filter is probably what you have. 730 system capacity is listed @ 10.5 gallons, but unless you purge all the cylinders you won't need much more than 5 or 6. Full level is 12" below the fill/breather cap.[/quote
You are right about the air filter number, my mistake. I've been doing many filters lately and I got them confused. Thanks for the info on the correct filters and capacity. You save me some heart ache. Thanks. SS |
| Back to top |
Jetbird Regular
Joined: 29 Jul 2012 Posts: 94 Location: Central Massachusetts
Posted: Wed Jan 23, 2013 8:37 pm Post subject: Re: 730 series loader hydraulic fluid capacity |
Hi sam, I did this job on my '68 3400 with 730 loader and I had the 9" composite filter instead of the paper. I don't know when the cutoff was when they changed to the paper type. You need a good size allen wrench to remove the drain plug, bigger than I had so I bought one. I also changed my hoses on my return lines since they looked pretty bad and I didn't want to drain the system again to change them later. They were a bit expensive as I recall for just a couple of short hoses, but not too bad. |
| Back to top |
SuperSam New User
Posted: Thu Jan 24, 2013 8:38 am Post subject: Re: 730 series loader hydraulic fluid capacity |
Thanks for the post JB. I got this tractor about a year ago. It had just received a complete engine overhaul and, fortunately for me, all of the hydraulic hoses were replaced. My loader doesn't have a "level check plug". So I've crafted a dipstick made from aluminum stock. Now I can feel that, near the bottom, there seems to be an accumulation of sludge. It's going to be interesting to see what I find when I drop the bottom plate. SS. |
| Back to top |
Laneman Regular
Posted: Thu Jan 24, 2013 7:23 pm Post subject: Re: 730 series loader hydraulic fluid capacity |
I don't think 12" is the correct fill level, in my
730 loader manual on page 18 it states that 8" from
the filler plug opening is the full level. This is
with the loader on the ground and bucket curled back |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
