| Author |
Message |
WayneMo Regular
Posted: Tue Jan 22, 2013 8:28 pm Post subject: 641 voltage regulator specs |
Does anyone have the specs for a 641 regulator. That is for the point gaps, field & bat voltages, etc. |
| Back to top |
JMOR Tractor Guru
Posted: Wed Jan 23, 2013 2:01 pm Post subject: Re: 641 voltage regulator specs |
| waynemo wrote: | | (quoted from post at 00:28:43 01/23/13) Does anyone have the specs for a 641 regulator. That is for the point gaps, field & bat voltages, etc. | Wayne, I see no responses & they may be hard to come by, so I will give you some data that "may" be useful to you, in the absence of good hard data on your specific regulator. Ford cars, trucks, tractors of that general vintage were set to have cut out close at 6.3 volts, + or -0.3 and the regulator section set to regulate to a voltage of 7.3 + or -0.2.
Setting up a VR is not real simple. To do it correctly, one really needs good voltmeters, ammeters, variable loads, , small files & a lot of time/patience. Temperature needs to be cover-on operating temperature as well (this really make things slow!). Typically, the contact gap needs to be set, the armature air gap set, and the spring tension set to obtain desired end results. The only specs that I personally have related to these parameters are that "typical" contact gaps are 0.020, armature air gap on cut outs of these vintage Fords is 0.017, and voltage armature gap 0.035. Having said that, sometimes those armature gaps are set with contacts just closed & occasionally at contacts open by a specific gap. Springs, generally set the voltage at which contacts close and the combination of spring /armature air gap yields contacts opening voltage for the cut out. Reverse current plays a role, but not independently adjustable.
For VR section, springs, generally set the voltage at which contacts open and the combination of spring /armature air gap yields contacts closing voltage for the VR section. Not simple and somewhat of a lost 'art' at this day in time of all-electronic solid state controllers/regulators. Maybe someone will be able to come up with hard specifics for your specific regulator & you will get lucky. |
| Back to top |
teddy52food Tractor Guru
Posted: Wed Jan 23, 2013 6:32 pm Post subject: Re: 641 voltage regulator specs |
I think you pretty much covered it. Unless somebody has messed with it before, those gaps should be OK. Clean up the points & adjust the spring tention on the field relay. |
| Back to top |
WayneMo Regular
Posted: Wed Jan 23, 2013 7:41 pm Post subject: Re: 641 voltage regulator specs |
Thanks. These values will serve as a guide. I do not plan to make any radical adjustments. My idiot light seems to blink a lot and the voltage I measure running is a little low, 6.8 to 7.0 fluctuating. I plan to clean the contacts and maybe tweak the voltage reg spring force a little to get the voltage up over 7 to around 7.2. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
