| Author |
Message |
Herb Brdy New User
Posted: Wed Jan 23, 2013 8:18 am Post subject: clutch and pulley brake on 39 B |
can the four bolts be taken out to remove the unit that engages and disconnects the clutch or is there more to it. what I want to do is take it off so I can somehow take the slop out of the pulley brake. It is so worn it hangs at an angle. |
| Back to top |
alvan Regular
Posted: Wed Jan 23, 2013 8:39 am Post subject: Re: clutch and pulley brake on 39 B |
Yes take the 4 bolts out and it will come out in one unit fork in all . |
| Back to top |
Mike M Tractor Guru
Posted: Wed Jan 23, 2013 10:13 am Post subject: Re: clutch and pulley brake on 39 B |
Those can get VERY worn. But remember the pulley brake arm never did fit really tight to the shaft. Most also need the shaft built up and the housing rebushed too. |
| Back to top |
alvan Regular
Posted: Wed Jan 23, 2013 4:32 pm Post subject: Re: clutch and pulley brake on 39 B |
on mine I took a 1x1 1/4 bushing worked just fine no more play easy fix. |
| Back to top |
pbb Regular
Posted: Wed Jan 23, 2013 5:10 pm Post subject: Re: clutch and pulley brake on 39 B |
I took some brass shim stock and rolled it up to fix mine.I put a new clutch lever bolt in and replaced the 2 clutch rod pins with oversized ones.I had so much slop in mine it wasnt funny.It sure made a world of difference after fixing it. |
| Back to top |
Larry Baker Regular
Posted: Wed Jan 23, 2013 5:46 pm Post subject: Re: clutch and pulley brake on 39 B |
somewhere I still have a dozen or so of those plates which I believe is called a bearing ,they are nos that I measured to bore some in a repair.Make you some brass bushings and it will outlast the grandkids if the government dont take 'em first |
| Back to top |
Patsdeere Tractor Expert
Posted: Wed Jan 23, 2013 11:27 pm Post subject: Re: clutch and pulley brake on 39 B |
There is a gentleman in the midwest that has a jig for those clutch pieces and will bore and bush them to as good as new. I sent him 2 and they came back in great shape. I think his name was Mike, but can't remember exactly where he was. I found his name here on ytmag. A little searching and you should be able to find it. |
| Back to top |
Posted: Wed Jan 23, 2013 11:32 pm Post subject: Re: clutch and pulley brake on 39 B |
just did a little searching and here is the info:
Give Mike Williams in Clinton, IA a call at 563-243-4928. He can fix you right up.
M & J ENTERPRISES
Mike Williams
Clinton, IA 52732
563-243-4928
As I remember it was about $200, but came back nicely fixed. |
| Back to top |
Herb Brdy New User
Posted: Fri Jan 25, 2013 2:42 pm Post subject: Re: clutch and pulley brake on 39 B |
Thanks to everbody for the information, it helped a lot |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
