| Author |
Message |
Lynn Patrick Regular
Joined: 23 Jun 2008 Posts: 161 Location: West Branch, Iowa
Posted: Wed Jan 23, 2013 9:00 am Post subject: Cub Cadet 1250 problem |
Hi Guys! I'm new to this site, usually hang out on the Ford side. I have a CC 1250 that when I last ran it last fall I had to keep increasing the pull on the choke to keep it running as I finished the last few rounds of mowing. I just ran a compression check and it was 60 lbs. It has leaked oil as long as I have owned it (4-5 years), I think from the front seal, but has always run great. Is this good compression for this engine? Any hints what to look for before I tear it down to repair the oil leak?
Thanks,
Lynn |
| Back to top |
dhermesc Tractor Guru
Posted: Wed Jan 23, 2013 9:46 am Post subject: Re: Cub Cadet 1250 problem |
Measuring compression can be a trick as those, the engine have a compression release valve at low RPMs. However if accurate the 60 PSI reading is low - it should be in the 110 to 120 PSI range.
It sounds like you have a blown headgasket and you'll want to fix that ASAP as the lean condition really heats those engines up causing more damage.
Fixing a head gasket on a 1250 is a PIA compared to a 129 or a 127 due to all the heat sheilds but its doable if you have a torque wrench. |
| Back to top |
kennell Long Time User
Posted: Wed Jan 23, 2013 11:11 am Post subject: Re: Cub Cadet 1250 problem |
Lots of times when you need choke to keep them running its dirt in the carb.Take your carb apart Throw your body in a bucket of carb cleaner for a day or two and thenn blow out all the passages.You should notice a big difference after that. Kent |
| Back to top |
I Luv Farmalls Guest
Posted: Wed Jan 23, 2013 2:51 pm Post subject: Re: Cub Cadet 1250 problem |
Mine did the same thing last fall, I poured some sea foam in it and two minutes it ran like new. |
| Back to top |
Ken Ind. Regular
Posted: Wed Jan 23, 2013 8:55 pm Post subject: Re: Cub Cadet 1250 problem |
My 1650 did that also last spring shot some carb cleaner in it while running and cleared up ran good all summer,kenny. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
