| Author |
Message |
Raydex 234 Regular
Posted: Wed Jan 23, 2013 5:11 pm Post subject: Wheel spacers. |
I got a 89 GMC 1 ton single rear wheel pickup. It has the Dana 60 rear end in it. I would like to put 2002 GMC aluminum rims on it. I have had them on there already but the rims hit the fins on the drums and do not allow it to tighten right. I tried cheap 1/4 inch spacers and that worked but I didn't think I had enough turns on the lug nuts. I was also worried that the cheap spacer might corrode or break. Has anyone used wheel adaptors or spacers on their tow vehicle? I was wondering how they hold up to heavy towing. Any comments welcome. Thanks. |
| Back to top |
caseyc Long Time User
Posted: Wed Jan 23, 2013 7:48 pm Post subject: Re: Wheel spacers. |
I would never use spacers in a situation like that. Find some different wheels. That's a disaster waiting to happen. Sorry.
Casey in SD |
| Back to top |
bobs old iron Tractor Expert
Posted: Wed Jan 23, 2013 8:22 pm Post subject: Re: Wheel spacers. |
i agree with caseyc, had a old p/u, even though 1/2 ton, going down street, wheel seperated from spacer, lucky, the drum dropped down on wheel, ddidn't loose control. came to slow stop,,, depending on the size of your rim size, just go another rim size larger, if not too costly,, |
| Back to top |
cd1 Regular
Posted: Thu Jan 24, 2013 8:14 am Post subject: Re: Wheel spacers. |
I'd either find other wheels or swap in a new rear end, they aren't worth much, hardest part might be the brake booster matching the newer disc brakes. |
| Back to top |
JimEvans Regular
Posted: Thu Jan 24, 2013 9:05 pm Post subject: Re: Wheel spacers. |
GM wheels are hub-centric which means the wheels are aligned by the hub of the drum. A cheap spacer will not work. You will need an expensive spacer that retains the hub pilot so the wheels will still be aligned. |
| Back to top |
bradk Tractor Expert
Posted: Wed Jan 30, 2013 5:35 am Post subject: Re: Wheel spacers. |
I have similar spacers(click below) on my 03 Suburban with big tires and 6" lift and they work great.They bolt on your existing hub and the wheel gets bolted to the new spacer so you don't get short on threads.
here
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
