| Author |
Message |
PCH Regular
Posted: Wed Jan 23, 2013 6:36 pm Post subject: stroking a 226 continental |
I thought I had a 244 but bot te head off and took out a piston did some measuring turns out a 226. Any know where the best place to find parts for these engines?How big it canbe bored and how much it can be stroked? |
| Back to top |
VTParts Guest
Posted: Wed Jan 23, 2013 10:01 pm Post subject: Re: stroking a 226 continental |
I have parts for this engine.
802-782-2409 |
| Back to top |
Old-n-Grumpy Regular
Posted: Thu Jan 24, 2013 4:55 pm Post subject: Re: stroking a 226 continental |
I have the same question. How big can this engine be bored and stroked? |
| Back to top |
PCH Regular
Posted: Thu Jan 24, 2013 5:16 pm Post subject: Re: stroking a 226 continental |
It sure is hard to find alot of information on this engine. I guess we will have to keep looking. |
| Back to top |
Goldsburg Regular
Posted: Thu Jan 24, 2013 6:24 pm Post subject: Re: stroking a 226 continental |
F226 parts are widely available, just be carefule when ordering. It would be best to provide engine serial number. You can google Foley Engine. They have tons of flathead Continental parts. You can also try Jerry Moon at Montes Equipement in Chicago. Again, google is your friend.
With regards to "performance" parts, everything is going to be custom unless you want to stop with 0.060" over pistons.
You could bore much bigger, but it will also cost more money. You could install a performance cam grind (I can help). You could also look to stroke. I am sure that 3/4" would fit. The big question is: Is it all worth it? IMHO, that answer is NO. The best running F226 engine (at stock +20% over, mind you) is going to top out at around 75HP. With some mild massaging, you can get a near stock 44 to that for 1/4 of the money.
If you really want to pull a flathead Continental and the pullers in your area aren't that knowledgeable (many aren't), then you should look to purchase a B427 flathead, M330, or M363 Continental to drop in.
Perhaps Jerry at Montes could help you locate one. You will probably have about the same money in purchasing and installing the bigger flathead than working over a F226...
Regards,
Goldsburg |
| Back to top |
Mike in Mn. Long Time User
Posted: Thu Jan 24, 2013 9:13 pm Post subject: Re: stroking a 226 continental |
About 25 years ago I was going to put a 244 in a Massey tractor to farm with, just cause I like the way they sound, found one in an Oliver combine, talked to Twin City Engine Re-builders at that time, they were a Continental Dealer, they told me to find a 226 and OH that cause the 244's all cracked between the valves. I still run that 226, bored 40 over, It's my hay baling tractor, don't have much power and nothing on the bottom end, but wound up on the baler it works good. I have a 44 puller with a warmed up 260, it will out pull that 226 about 3 to 1. I would make a new plan. |
| Back to top |
Massey 101 Regular
Posted: Fri Jan 25, 2013 4:44 am Post subject: Re: stroking a 226 continental |
Here is a F 226 pulling, around 100 HP...
280 psi, would pull 3rd gear with a long chain....
| Back to top |
Goldsburg Regular
Posted: Fri Jan 25, 2013 6:08 am Post subject: Re: stroking a 226 continental |
You didn't say how fast you are turning it...
Regards,
Goldsburg |
| Back to top |
Massey 101 Regular
Posted: Fri Jan 25, 2013 6:15 am Post subject: Re: stroking a 226 continental |
I pulled it at 2380 rpm... |
| Back to top |
Massey 101 Regular
Posted: Fri Jan 25, 2013 6:24 am Post subject: Re: stroking a 226 continental |
Now I pull a built Chrysler 265 block ....more HP!
| Back to top |
Vtparts Guest
Posted: Fri Jan 25, 2013 7:09 am Post subject: Re: stroking a 226 continental |
As it turns out I do not have parts. Sorry |
| Back to top |
Posted: Fri Jan 25, 2013 9:41 am Post subject: Re: stroking a 226 continental |
Goldsburg, will a B427 flathead, M330, or M363 Continental bolt right in? Or would there need to be some massaging to get one of these to bolt in? |
| Back to top |
PCH Regular
Posted: Fri Jan 25, 2013 11:59 am Post subject: Re: stroking a 226 continental |
Massey 101 What do Ineed to do to the 226 to get close to 100 hp? And where is the best place to find these parts? |
| Back to top |
Massey 101 Regular
Posted: Fri Jan 25, 2013 12:47 pm Post subject: Re: stroking a 226 continental |
Here is my e-mail. wardspuller@gmail.com |
| Back to top |
Quefan Guest
Posted: Fri Jan 25, 2013 1:36 pm Post subject: Re: stroking a 226 continental |
Block face/face
MH 44-6___F226____25in
MH203____M330___30 3/4
Cont.______B427____33 1/4
44-6 rear to pulley 28 1/2
Big shoehorn |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
