| Author |
Message |
Hendrik Long Time User
Joined: 17 Feb 2000 Posts: 689 Location: Ede, The Netherlands
Posted: Thu Jan 24, 2013 1:45 pm Post subject: OT mounting oil cooler |
The Fiat 124 Spider I bought last year has an add on oil cooler for the auto transmission.
Would like to mount this cooler a little better. It sits between the grill and the radiator (engine coolant cooler). In the pic the radiator is removed.
The overall dimensions are approximately 13 by 5 by 0.75 inches.
Since the cooler has no mounting ears, I am thinking of a rubber strap looped through each of the three U bends in the pipe and attached to a vertical post to be mounted between the cross members below and above the cooler.
Open to your learned and practical suggestions!
Appreciate your help, Hendrik |
| Back to top |
Rick Kr Tractor Expert
Joined: 24 Aug 2004 Posts: 2355 Location: Mid Michigan
Posted: Thu Jan 24, 2013 3:05 pm Post subject: Re: OT mounting oil cooler |
We do this all the time on drag cars.
You may have to fab something up to mount it to, like two stout brackets on each side. Then we put 3/8 or 1/2 inch thick foam (dense, not soft) between the mounts and the cooler. Then use very heavy zipties to hold it down. Never had one break yet.
Rick |
| Back to top |
showcrop Tractor Guru
Posted: Thu Jan 24, 2013 4:46 pm Post subject: Re: OT mounting oil cooler |
Good thing it's not a ford truck or you would have to put it under the intake manifold. |
| Back to top |
MARK ROBKE Regular
Posted: Thu Jan 24, 2013 6:30 pm Post subject: Re: OT mounting oil cooler |
When they come in a kit, they have little rubbers that you slip plastic wire ties thru and secure directly to radiator.Mark |
| Back to top |
mtn.man Regular
Posted: Thu Jan 24, 2013 7:40 pm Post subject: Re: OT mounting oil cooler |
Go to NAPA they can get you the mounting kit for add on trans. coolers. |
| Back to top |
Jeff B. Regular
Joined: 11 Oct 2008 Posts: 414 Location: Idaho Falls, Id.
Posted: Thu Jan 24, 2013 7:44 pm Post subject: Re: OT mounting oil cooler |
Go to a place that sells those kind of coolers and ask for a Hayden # K210 or Derale # 13010. It"s the kit you want with the rubber foam pads and the wire tie type mountings. Transmission supply places will have them. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
