Just a Thought...861 Head Gasket
Goto page 1, 2  Next
Tom Bond
PostPosted: Thu Jan 24, 2013 6:00 pm    Post subject: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
With the weather being so cold outside, should there be any consideration about remounting the head and torqueing it down with the parts so cold? I normally only turn on the heat in the garage when I'm out there so the block and head are really cold. Would it have any adverse affects on it after I get it together and start it up? All the parts are cleaned and just waiting to pick up the gasket set and thermostat at NAPA when they arrive. Only thing left before assembly is chase all the bolt hole threads to make sure they're clean.
souNdguy
PostPosted: Thu Jan 24, 2013 6:29 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
our hands are gonna worry more about the cold than the head and deck will.
slap it on. I can't say that I've ever paid attention to temps other than when painting when doing wrench turning.
just rememebr after torquing, that you need to fill rad and cooling system, then run it till warmed then retorque.. and would be a good time to double check valve settings.
me? on a issue witha head gasket? it's fill with clean water, warm up and test it like that till I was sure I had no leaks into crankcase. water in oil is bad.. coolant in oil will wipe out bearings..
if it is freezing in your area.. remamber to drain block and rad of the water, or add coolant after you test it, and then let it circulate to make sure you don't have a pocket of cold unmixed water trapped in a lower rad or block.
( IE i always test a engine assy with pure water not coolant .. just in case). DO rememebr to add coolant / or drain it if freezing though...
Tom Bond
PostPosted: Thu Jan 24, 2013 6:57 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Excellent point souNdguy. Thank You! I'm hoping no damage was done to bearings. Motor ran no more than 10 mins at 1000 RPMs before I caught the coolant in oil. Oil pressure was still 35 psi when at idle and no unusual noises. If no leaks, I figure I'll drain water and refill with coolant, fresh oil and filter, run it a couple days and then another oil and filter change depending on what oil condition looks like.
andyin ct
PostPosted: Fri Jan 25, 2013 2:28 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Did you carefully clean the block and head surfaces? I use a razor blade and scrape the surfaces. If they are not completely clean you will have problems.
Will Gumbert
PostPosted: Fri Jan 25, 2013 1:53 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
I haven't read all of the posts about the head gasket change you're working on so forgive me if this has already been discussed. At the risk of being insulting (which I definitely don't want to be) I was just wondering if you have a shop manual to refer to during re-assembly? Of course there is a correct bolt tightening sequence and torque, and other things like putting the push rods back in the original locations, etc. Just checking... Wink -Will
Tom Bond
PostPosted: Fri Jan 25, 2013 3:05 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Absolutely NOT insulting at all. I can't tell how much you've all helped with this change. All the little tricks and tips come from your experiences. Yes, I have the shop manual with all the specs and I'll follow them to the "T" when reassembling. Felpro gasket set came with push rod cover gasket also so I'm going to pull that cover tonight when I do my final cleaning and thread chasing before assembly. Won't hurt and I can see whats up inside there. Gasket set came with instructions that said, "Install head gasket in direction of markings, otherwise install gasket." So, only markings on my gasket, just some lines. Which side goes to block?
Will Gumbert
PostPosted: Fri Jan 25, 2013 3:45 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
I think if you lay the head gasket down on the deck surface on the block, and looking at the openings in the casting, it will only go on one way. Did you decide to use some copper coat on the gasket? I'm not recommending it, just curious. You seem like a very methodical and meticulous guy with your tractor work. That's good and the knowledgeable people here will give you sound advice as they have for me. I try, but a few times I have said the wrong thing and they always set me straight! (good thing!) -Will:
john in la
PostPosted: Fri Jan 25, 2013 4:12 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Is that even the correct gasket?????????????????
But anyway that gasket will only go on one way. If it made a differance there would be FRONT stamped on the gasket.
Tom Bond
PostPosted: Fri Jan 25, 2013 9:40 pm    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
John, you called that one! Looks like the set I got from NAPA might be for another series even though it's listed for the 801, 172 gasser like mine. I might have an issue returning it as all Felpro products are marked non returnable if opened. But I think I have a legitimate beef if they're description is wrong. Steiner shows one with the appropriate water jacket port in the gasket. I'll have to order that set I guess. I also noticed my head is a remanufactured one. Part #310100. Doesn't look like an issue though. Does the distributor have to come out to remove the push rod cover? I tried to remove cover to clean it up under there and no luck but didn't want to force things this late in the game. If I have to pull it, is there any seal or "O" rings I need to get while I'm ordering the new head gasket set? Thanks Again!
ASEguy
PostPosted: Sat Jan 26, 2013 2:51 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
The only time I am concerned about the cold is when I'm building an engine and the parts aren't all the same temperature. Checking the fit of pistons/block requires they be at the same temperature.
Hobo,NC
PostPosted: Sat Jan 26, 2013 5:34 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
[quote="John in La"](quoted from post at 04:12:58 01/26/13) Is that even the correct gasket?????????????????
That's a good catch Exclamation ,,, I have both the 7/16 and 1/2" head bolt styles rite in front of me ( Victor Reintz) Both have the rectangle hole....
3152 for 55 to 57 7/16" head bolts
5795 for 58 to 64 1/2" bolt holes
The 5795 has a steal ring around the rectangle port the other does not...
The firing ring is different on both I have never till now noticed the difference... I was under the impression the head bolt size was the only difference...
This is why I always check the old again the new
Wink Tom what is the fel-pro #
Tom Bond
PostPosted: Sat Jan 26, 2013 6:44 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
The Fel-pro # 7761-B1. It's out of their head gasket kit # HS7761B2.
john in la
PostPosted: Sat Jan 26, 2013 6:50 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
OK let me think out loud here for a second and see if we can figure this out.
I went to the Fel Pro site and found they gave you what felpro has listed as the correct gasket 7761-B-1. You got set HS-7761-B-2. The picture shows the gasket you have and you can see the number stamped on your gasket picture.
So now we have to wonder is that a felpro mistake or do they know something we are over looking. If it is a mistake I wonder how many have used this gasket in the past and are now posting here about over heating problems.
So just to get a better idea of the problem I looked at the gasket for the 134 motor 7632-B
and it looks more like what you need so at least felpro got it right. To bad the bore is differant and I do not know the details of that gasket or I MIGHT suggest using that gasket.
On the other hand if you look on this site or even the main Tisco parts site you will see that the 1/2 bolt gasket for the 134 and 172 is the same gasket. The gasket for the 7/16 is listed as a differant gasket for the 134 and 172 but that could be because Tisco sells a metal clad gasket for the 134 and a non-metallic gasket for the 172.
I wonder if contacting the felpro customer service and technical inquiries line at, 1-800-325-8886 would produce a answer to this problem.
Before I took anything else apart I would decide what path I was going to take. Most tractor sites sell a head gasket replacement set that only has the head gasket; valve cover; and manifold gasket. The next step up is a complete gasket set at more than twice the money. What you have is a head rebuild set. It is going to have some extra gaskets in it like the side cover. So if you go with another set you may not get a side cover gasket. But anyway that cover is just stuck on. They leak easy cause the cover gets bent so many gob it on with gasket sealer.
I do not know what path I would take. I would be very tempted to talk to felpro customer service and see if they would trade me the gasket for a 134 and try it.
Will Gumbert
PostPosted: Sat Jan 26, 2013 7:39 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Since the FelPro photos show a port opening for the 134 gasket and not for the 172 gasket, is there any chance this is actually a 134 motor? Tom, what casting # is on the right side of the engine block?
Also, take a close look at the shape of the combustion chamber in the head and compare it to the old and new gasket. The new gasket appears to be made for a larger chamber with a different shape. -Will
JMOR
PostPosted: Sat Jan 26, 2013 8:38 am    Post subject: Re: Just a Thought...861 Head Gasket Reply to specific post Reply with quote
Also, I have a very cloudy recollection of a change in coolant flow in this series of engines, somewhere along the way & blocking those ports may have been the way it was done. Nine different head gaskets & some head numbers in this thread:
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ford&th=486779
Goto page 1, 2  Next
Page 1 of 2
