gasket and bearing Kit for rd 501
rd engine rebuild?
PostPosted: Fri Jan 25, 2013 6:33 am    Post subject: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
hey i was wondering where i could find a whole gasket kit or bearing kit there has to be something out there i see too many tractors run those engines?
NGI
PostPosted: Fri Jan 25, 2013 7:15 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
You wont find new main bearings for these engines. However, you can go to your local NAPA and get fel-pro set# HS7953S. Its a head set for the 450-501 engines.
rd engine rebuild?
PostPosted: Fri Jan 25, 2013 7:23 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
thanks, i had heard that 5.9 cummins bearings where close is there any truth to that? if so what all has to be done to make them work?
unstylish
PostPosted: Fri Jan 25, 2013 7:24 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
I think u have to have the crank reground and use a Cummins main bearing
Supercharged 3800
PostPosted: Fri Jan 25, 2013 7:59 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
Try Murphys for the bearings.
James Tierney2
PostPosted: Fri Jan 25, 2013 10:22 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
I should have a main set in std and possibly .020 (have to check) - please email if interested.
oldihpuller
PostPosted: Fri Jan 25, 2013 3:58 pm    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
Sam Winer surplus military in Akron,Ohio has a RD 501 valve grind gasket set on ebay now, item# 220708379622.
They may have other parts available.
lmbky
PostPosted: Sat Jan 26, 2013 8:12 am    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
i got a set of rod bearings std never out of box id sell cheap,started a rebuild n went n different direction,call 270 231 3651 if interested
Mike Genrich
PostPosted: Sun Jan 27, 2013 6:25 pm    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
I just got done putting an rd450 together this afternoon thats going in a w40. watch out for the nos army gaskets on ebay. They are for the early engines and the water jacket holes dont line up, one hole towards the rear of the gasket is a hole and needs to be a slot. They may work im going to try it. Bearings seem to be out there in nos form but there a b-tch to find and new ones arent avalible threw a parts store. cam bearings and lifters for a 1206 fit the red diamond engines. lots of luck!
Mike Genrich
PostPosted: Sun Jan 27, 2013 6:26 pm    Post subject: Re: gasket and bearing Kit for rd 501 Reply to specific post Reply with quote
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
