Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Gear oil for M
Patrick HMD
PostPosted: Fri Jan 25, 2013 1:51 pm    Post subject: Gear oil for M Reply to specific post Reply with quote
Now that I have installed my pulley gearbox I was advised to pour a quart of lube at the top filler to be sure the gears are lubed before start up. Not knowing what kind of gear lube is in there now, I bought a quart of Traveller SAE 85W-140. Will that do?
A large amount of lube oozed out the oil fill inspection hole when I removed the plug, maybe 1 or 2 quarts, but no water. I'll leave the plug off till after I add the quart to the gearbox which will probably bring the oil level up a bit more. An over filled gearbox is not a good thing I've been told. It will cause leaks where there shouldn't be any.
Am I on the right track here?
TIA
Patrick
'49M
jgriff
PostPosted: Fri Jan 25, 2013 1:59 pm    Post subject: Re: Gear oil for M Reply to specific post Reply with quote
If it has any water in it it will be in the bottom not the top
D7fever
PostPosted: Fri Jan 25, 2013 2:00 pm    Post subject: Re: Gear oil for M Reply to specific post Reply with quote
You are not going to get water out of any plug hole
except the bottom one.... you can take it out
carefully, and if only gear oil comes out, put it
right back in, if water comes out, let all the water
drain then put the plug back in, unless you want to
change the gear oil. 85- 140 will work just fine.
Tracy Brown
PostPosted: Fri Jan 25, 2013 2:01 pm    Post subject: Re: Gear oil for M Reply to specific post Reply with quote
Crack your drain plug to check for water. It will be on the bottom.
rustred
PostPosted: Fri Jan 25, 2013 2:05 pm    Post subject: Re: Gear oil for M Reply to specific post Reply with quote
yes that will be fine.
i would open the drain plug at bottom and drain some of the thick gunk out.
1 quart either way is here nor there on these old clunkers, their not fussy.
Patrick HMD
PostPosted: Sat Jan 26, 2013 2:52 pm    Post subject: Re: Gear oil for M Reply to specific post Reply with quote
Well, I ended up with over 1 1/2 gal. of gear oil in the drain pan before i screwed the plug back in. And even then it was still seeping out a bit. Didn't realize I was carrying around that much excess baggage. I did loosen the bottom 2 drains and got very little water.
I can understand a quart plus or minus would not make that much difference, but 1 1/2 gals. seems like a lot, and I'm thinking it's due to water displacement. There was some water mixed in with the drained oil. The oil is very, very thick. As it was draining into the pan, it looked like cake batter being poured into a baking pan. That same consistency. Maybe thicker yet. I'm going to run it as is without the extra oil. I hope nothing blows up. lol
Thanks guys.
Patrick
'49M
