| Author |
Message |
Rob Mazza Guest
Posted: Fri Jan 25, 2013 2:20 pm Post subject: Super M head |
I brought my head for my Super M to the machine to have a valve job done and when they magna fluxed the head they found six small cracks around the combustion chamber, they said should be no problem, what do you guys think?
Rob |
| Back to top |
rustred Tractor Expert
Posted: Fri Jan 25, 2013 2:32 pm Post subject: Re: Super M head |
if thats what he said then ok, as we cannot see the head. post a pic. |
| Back to top |
minnemoman Regular
Posted: Fri Jan 25, 2013 2:46 pm Post subject: Re: Super M head |
when you put it back togeater you should defunetly use some block seal.
good luck and have fun  |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18206 Location: St. Cloud, MN
Posted: Fri Jan 25, 2013 3:06 pm Post subject: Re: Super M head |
If they go from, or into a valve seat, or spark plug hole, or on the edge into a water jacket, they are serious. if they start and stop, and are no longer than 1/2" to 5/8" I would leave them alone and use Bars leak in it as directed. If they ar bigger, Metal Stitching is a great repair. Jim |
| Back to top |
the tractor vet Tractor Guru
Posted: Fri Jan 25, 2013 3:07 pm Post subject: Re: Super M head |
OK so they found cracks BUT DID THEY PRESSURE CHECK THE HEAD with HOT WATER to see if they leaked????? NOBODY DOES THIS ANYMORE . |
| Back to top |
Posted: Fri Jan 25, 2013 3:14 pm Post subject: Re: Super M head |
block seal is useless on a compression leak. that garbage hardly will work on a gravity crack. it is only good if you want your rad cores plugged up.
as i suggested to post a pic then get advise, other than that its shooting in the dark. kind of a funny question ... the machinist looks at it and gives his version then we get asked ... "what do you guys think" i think the machinist is correct. |
| Back to top |
Posted: Fri Jan 25, 2013 3:23 pm Post subject: Re: Super M head |
my head doctor does the pres. test. but few and far between. i have seen these heads with cracks and affect nothing. |
| Back to top |
Duner Wi Tractor Expert
Posted: Fri Jan 25, 2013 5:03 pm Post subject: Re: Super M head |
My M head was RECAST 30 years ago and fails magna fluxe test but it does not leak anti freeze.
If it did not bother before it could work. |
| Back to top |
Rob Mazza Guest
Posted: Fri Jan 25, 2013 5:25 pm Post subject: Re: Super M head |
Its already off the mag table, they say it will be ok. I really want to put the high compression pistons in it, I have talked to guys who have done it and really like it. Where's the best place to buy them?
Rob |
| Back to top |
Posted: Fri Jan 25, 2013 5:41 pm Post subject: Re: Super M head |
On this site. Tisco is a solid brand. Good prices and nobody has complained about the quality ot fast delivery. Jim |
| Back to top |
sflem849 Tractor Guru
Joined: 15 Jan 2007 Posts: 5352 Location: SE Wisconsin
Posted: Fri Jan 25, 2013 7:53 pm Post subject: Re: Super M head |
| The tractor vet wrote: | | (quoted from post at 16:07:54 01/25/13) OK so they found cracks BUT DID THEY PRESSURE CHECK THE HEAD with HOT WATER to see if they leaked????? NOBODY DOES THIS ANYMORE . |
Pakes Engine and Machine in Janesville, WI does. |
| Back to top |
stonerock Guest
Posted: Sat Jan 26, 2013 6:11 am Post subject: Re: Super M head |
tisco pistons are fine.one M I have has 11 cracks in the head daily runner at 75 hp it is ok. most power is in the cam have a new one ground for the hp you want. don't plane the head you need the cc's for fuel mixture. make the compression up with the thickness of your head gasket. use a LP intake and exhust. drill the carb out. open the head up but don't polish. you should have a strong runnin M. I have six of them for play |
| Back to top |
Posted: Sat Jan 26, 2013 6:21 am Post subject: Re: Super M head |
| stonerock wrote: | | (quoted from post at 07:11:45 01/26/13) tisco pistons are fine.one M I have has 11 cracks in the head daily runner at 75 hp it is ok. most power is in the cam have a new one ground for the hp you want. don't plane the head you need the cc's for fuel mixture. make the compression up with the thickness of your head gasket. use a LP intake and exhust. drill the carb out. open the head up but don't polish. you should have a strong runnin M. I have six of them for play |
Why should you port and not polish the intake? I was told for such a low RPM motor P&P work wouldn't do much good. Just interested to hear what you know. |
| Back to top |
ss409 Regular
Posted: Sat Jan 26, 2013 6:34 am Post subject: Re: Super M head |
before you pour 500 or more into it n risk it, please keep in mind that the new 450LP cyl heads can be bought for 1100 or less n never worry bout it again n pick up some power. just a thought. |
| Back to top |
stonerock Guest
Posted: Sat Jan 26, 2013 7:34 am Post subject: Re: Super M head |
open the runners up in the head you want it to breath easy and match intake and exhust and gaskets.but leave it rough so it causes turbulence to mix gas and air better. rocker rollers will also help.[250.00] for about 4 hp.you will need them if you take too much off of the head |
| Back to top |
