ford 4600 pto won't turn off
David1
PostPosted: Fri Jan 25, 2013 4:42 pm    Post subject: ford 4600 pto won't turn off Reply to specific post Reply with quote
Could extra cold weather have anything to do with the pto not turning off.
paul
PostPosted: Fri Jan 25, 2013 5:52 pm    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
I'm not familiar with a 4600 exactly, but many Ford pto's use hyd pressure to on/off the pto clutch, as well as a brake for the pto.
As they get old, the pressure on that system gets light, and the pto will spin, the brake gets too light.
Letting it do so wrecks the brake completely, but most folks do, until the pressure doesn't build up enough to engage it any more, then a total rebuild.
A real Ford mechanic likely can be much more accurate than my cliff note explination.
--->Paul
Jerry/MT
PostPosted: Fri Jan 25, 2013 7:14 pm    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
My Ford 4610 does that in cold weather.
Ultradog MN
PostPosted: Sat Jan 26, 2013 5:29 am    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
Take a 2X4 and wedge it against the 3 point linkage to try stopping the pto from turning.
If it stops easily that way it is probably just a combination of cold oil and the pto brake getting worn. In which case I wouldn't worry about it.
If you can't stop it with a 2X4 then you have other problems and will need to diagnose further.
WGWKy2
PostPosted: Sat Jan 26, 2013 5:57 am    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
It is a Ford thing, cold oil, broken bkake spring, worn brake shoe, one of mine does that the other stops just try to remember which tractor i'm driveing. Got that on the list if I ever take the top off.
Fordfarmer
PostPosted: Sat Jan 26, 2013 6:25 am    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
My 4600 does the same when it's cold. It will stop once the oil warms up, either from use or when warmer weather gets here. The brake on them never was real strong...
RodinNS
PostPosted: Sun Jan 27, 2013 2:29 pm    Post subject: Re: ford 4600 pto won't turn off Reply to specific post Reply with quote
If it only does this during cold weather I wouldn't worry about it. They can do that. It should stop once the oil warms up tho.
If it doesn't stop... then it oculd be an issue with the brake piston or more likely that the brake shoe has lost it's lining. That's the kind of repair that is most often left until there's another reason to go rooting around in th eback end or the transmission is removed.
Rod
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
