MF 50-202 ENGINE SWAP
jon barton
PostPosted: Fri Jan 25, 2013 8:43 pm    Post subject: MF 50-202 ENGINE SWAP Reply to specific post Reply with quote
i have a MF202 tractor with a z134 engine that has a rod sticking out of the block. i also have several MF 50"s with the Z134 engine. is it a direct swap to change the engines from the 50"s to the 202? or are there differences that require alterations? (flywheel, clutch, linkage, etc??) thanks for your help
Tony in Mass.
PostPosted: Fri Jan 25, 2013 9:31 pm    Post subject: Re: MF 50-202 ENGINE SWAP Reply to specific post Reply with quote
Umph. An older- pre MF150 ag 50, not a later industrial 50 right? More than maybe.
First glance, the steering is different enough, that will have to get changed out. front end-pivot housing? basket? 'might be fine, but not at the column. Flywheels ,clutches, again a maybe. Is the 202 a single stage like mine? And does the 50- most likely, have a 2 stage? Then even the flywheels will have to get swapped. I am in the process of doing the exact same thing, most of the story is in the fergie forum, from Christmas. And like you, I have a dead 50, and hopeless diesel 35- and a soon to be rebuilt z134 from a 202... not a dead end, not a big extra expense, but kinda confusing. Best to tear the 202 all appart, and a 50, lay it all out around the yard...and hope for the best...
MKinOntario
PostPosted: Sat Jan 26, 2013 8:04 am    Post subject: Re: MF 50-202 ENGINE SWAP Reply to specific post Reply with quote
Put them side by side and have a good look. Likely the basic engine is the same and the rest you could change over.
