| Author |
Message |
PretendFarmer Regular
Posted: Sat Jan 26, 2013 4:11 am Post subject: siezed clutch? |
On my 140, I just got the motor back together. I bought this tractor not running. The clutch is adjusted all the way out. When Ipress the pedal in, the clutch does not disengage. Is it siezed? |
| Back to top |
Tom Fleming Tractor Expert
Joined: 06 Jun 2007 Posts: 2039 Location: pennsylvania
Posted: Sat Jan 26, 2013 5:35 am Post subject: Re: siezed clutch? |
Well, the clutch disk could be rusted (stuck) tot he fly wheel. Are you doing an "in tractor" job on the engine? I would think so, since you would have to remove the clutch (or at least see it) with the engine removed. Remove the lower inspection plate to see what is going on if you have not removed the engine. You should have approx 3/4" - 1" free travel in the clutch pedal to be correctly set.
Need more info. |
| Back to top |
Posted: Sat Jan 26, 2013 5:40 am Post subject: Re: siezed clutch? |
What info would you like? Im not sure.... its a 140, and when I hit the clutch pedal the clutch wont disengage.... |
| Back to top |
Posted: Sat Jan 26, 2013 6:02 am Post subject: Re: siezed clutch? |
are you doing an "in tractor" rebuild on the engine? Have you inspected the clutch? |
| Back to top |
Posted: Sat Jan 26, 2013 6:39 am Post subject: Re: siezed clutch? |
Ok, I see on your other post about the engine, that this was an in-tractor rebuild.
REmove the clutch inspection cover, and see if the clutch disc moves when the clutch is engaged vs. di-engaged. If this had been sitting for awhile, the disc can rust to the flywheel. The splines can also become rusted.
Best technique to free up a stuck clutch disk (if it isn't too too badly rusted) is to start the old girl up in first gear and with the clutch pushed in, firmly tap the brakes to free it up while running (moving). There are other ways too that are a little more agressive, that I am not a fan of. this of course assumes you have good brakes. |
| Back to top |
ken house Regular
Posted: Sat Jan 26, 2013 9:32 am Post subject: Re: siezed clutch? |
i assume that the engine will run. if you have wide open space available and a hill, get the tractor on the hill, heading downwards; get on the tractor, put the tractor in 3rd gear and start it. drive around with your foot pressing the clutch pedal. maybe it will come loose. throttle the tractor up and down, press the brake pedals and then release them. be careful doing this, make sure you have plenty of space. |
| Back to top |
Posted: Sat Jan 26, 2013 10:26 am Post subject: Re: siezed clutch? |
and make sure BOTH brake peddles are locked together........... |
| Back to top |
mkirsch Tractor Guru
Posted: Sat Jan 26, 2013 11:36 am Post subject: Re: siezed clutch? |
The only other option is to split the tractor and remove the clutch to get it freed up.
Just make sure the transmission is in NEUTRAL when you start fiddling with the engine to finally get it running. |
| Back to top |
Oldiron29 Long Time User
Posted: Sat Jan 26, 2013 2:59 pm Post subject: Re: siezed clutch? |
Pretend, If your clutch is stuck and spinning tranny and you have real cold gear oil you could have found why you engine is cranking slow.
oldiron29 |
| Back to top |
El Toro Tractor Guru
Posted: Sat Jan 26, 2013 4:02 pm Post subject: Re: siezed clutch? |
You may need to split the tractor. Hal |
| Back to top |
Posted: Sat Jan 26, 2013 4:14 pm Post subject: Re: siezed clutch? |
ok, we all need to slow down. Myself included.
Pretend Farmer: take a minute, and remove the clutch inspection plate. Get a 2nd person to help you with the next step. You will need a flash light.
Have someone work the clutch while you look inside the inspection hole (actually the throwout lube access hole). It is not very big, so not alot to see. However, you should be able to see the overall condition of the pressure plate and disk. you can then watch as the helper works the clutch. You should be able to see whether or not the disk is rusted and not moving.
Before we go down many different, and potentially correct suggestions, let's start with the simple ones, and get progressively deeper up to and including a split of the tractor.....which is a definite possibility. I am not at all familiar with the 140, but I am assuming it has the small opening for greasing the throwout, which might give enough line of sight to tell if the disc is frozen to the fly wheel or not. I may be wrong, as I said, I am not familiar with anything newer than an A, B, or C. |
| Back to top |
Dennis K (WA) Regular
Joined: 05 Mar 2009 Posts: 264 Location: Ridgefield, Wa.
Posted: Sat Jan 26, 2013 7:41 pm Post subject: Re: siezed clutch? |
If it has an inspection cover, grease access, hole like the older models;
With engine off and another person holding the clutch pedal down, go through the hole with a punch to the hub of the clutch plate and rap it hard with a hammer. Unless it is severely stuck it will free itself.
Another possibility is the pilot bushing in the flywheel, but not as likely.
Dennis |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
