Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
plasma cutters
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
torch guy
PostPosted: Sat Jan 26, 2013 6:47 am    Post subject: plasma cutters Reply to specific post Reply with quote
I'm getting more and more aluminum fabrication requests and am beginning to need one. I was looking at the Miller spectrum 875 and a thermal dynamics cut master 82. My shop is all blue and was leaning toward the Miller but I'm not against another color/brand. Let's hear some suggestions and experiences. Thanks.
Bus Driver
PostPosted: Sat Jan 26, 2013 7:18 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Some brands have very expensive consumables. Investigate that aspect before purchase. Hypertherm was my choice.
JD Seller
PostPosted: Sat Jan 26, 2013 7:41 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
The Miller is the better of the two you are talking about. I personally have an older Hobart and it works fine. The newer Hobarts are not the same machine. They are more of a consumer grade product now.
You will find that you will use the Plasma cutter much more than you thinking. I even use mine to cut bearings out of cases and such. Fast and the surrounding metal does not get as hot.
Puddles
PostPosted: Sat Jan 26, 2013 7:46 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Hypertherm and Thermal Dynamics are hard to beat. With my Hypertherm 1250 on my CNC table I get a minimum of 250-feet of cutting before I ever see any drop in quality of cut from the electrode or nozzle.
Remember if you're going to Tig weld aluminum after plasma cutting, you want to cut the object 1/32 to 1/16-inch big, and grind / sand to the desired size.
timcasbolt
PostPosted: Sat Jan 26, 2013 8:08 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Most consumables are pretty cheap on ebay.
504
PostPosted: Sat Jan 26, 2013 8:37 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Thermal Dynamics is the machine of choice. We sell all of them, but if it was my money it would be the TD. They were running a special for a while, buy the plasma and get a free 115V inverter stick machine.
GlenIdaho
PostPosted: Sat Jan 26, 2013 10:59 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
I just did considerable research on plasma cutters and ended up with a Hypertherm. Miller makes quality equipment, I have a Miller mig and it does all I want it to. You probably already know this, but I learned that you want to buy a plasma cutter that will cut material thicker than you intend to cut.
Stick welding
PostPosted: Sat Jan 26, 2013 11:36 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
What are you basing it on that the Miller is the better machine? I work at a full line Miller dealer and we don't even bring in Millers for display but try to keep the TD units in stock. Not saying the Miller isn't a good machine but the TD machines sell a lot more and we don't have any complaints with them. A lot of standardized parts as well.
Stan in Oly, WA
PostPosted: Sat Jan 26, 2013 4:47 pm    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Hi Puddles,
Why is that?
Stan
Puddles
PostPosted: Sat Jan 26, 2013 5:28 pm    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Stan it is the contaminates in the dross. I've been told only other way around this is to cut with Argon instead of air.
Ken Macfarlane
PostPosted: Sat Jan 26, 2013 6:41 pm    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Hypertherm here, works the very best.
DKase
PostPosted: Sat Jan 26, 2013 6:49 pm    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Hypertherm hands down! I researched and talked to several owners, and pro shops. Almost everyone told me Hypertherm. Only thing I do not prefer about mine is the switch on the back.
torch guy
PostPosted: Sun Jan 27, 2013 7:06 pm    Post subject: Re: plasma cutters Reply to specific post Reply with quote
Thank all you guys for the replies. I'll be looking more into the hypertherm and thermal dynamics and go from there.
blunosr
PostPosted: Wed Jan 30, 2013 2:36 am    Post subject: Re: plasma cutters Reply to specific post Reply with quote
I have often used wood working tools to cut aluminum (table saw, band saw, even a wood router). So long as you don't go too fast it works great.
I also want a plasma cutter, and have settled on the Hypertherm 45.
Bye for now,
Troy
