Gravely Tractor starter
Farmall Bob
PostPosted: Sat Jan 26, 2013 12:28 pm    Post subject: Gravely Tractor starter Reply to specific post Reply with quote
Hi, my Gravely Tractor starter doesn"t work. Can anyone tell me where to locate a good one. I went to NAPA to get a new one but they can"t find a replacement without correct information. Thank you.
Bob
ray hofstetter
PostPosted: Sat Jan 26, 2013 1:56 pm    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
2 wheel or 4 wheel Gravely? What's your starter doing?
I put new brushes in mine, good as new....
Farmall Bob
PostPosted: Sat Jan 26, 2013 3:30 pm    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
Hi Ray,
I replaced the parts several years ago with a kit, and it seemed to work for awhile. I took one to a repairman that works only on starters and he pulled it apart and won"t repair it said it was to bad. If I had a lathe I would have rebuilt it myself. If there was a better one out there I would like to know. Also there isn"t any spark so will have to go through the mag. Thanks.
Bob
boomers_influence
PostPosted: Sat Jan 26, 2013 5:09 pm    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
bob
can you tell us what make,model engine you have?
over the years gravely used many different engines.
also the model of the tractor.
thank you. boomer
SuperABen
PostPosted: Sat Jan 26, 2013 6:31 pm    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
FarmallBob, the original starters for all Gravely T-head engines were Delco Remy. I once heard you can take the guts out of a regular DR starter (like a Farmall) and do a transplant into your Gravely starter. I believe a few starters had the same body, but you would reuse the front flange mount and gear drive that the Gravely needed.
But I haven't done that transplant business to know if it works or not. All of the Gravely starters I have played with were not hopelessly gone, and were able to be rebuilt by a starter shop.
www.gravelyparts.com is Richard's Gravely. He used to have rebuilt/new starters available.
Here's a link I had in my bookmarks for a not so cheap version: http://www.amazon.com/STARTER-GRAVELY-TRACTOR-L-MODEL-1108311/dp/B0079PI7TA
Is the Delco tag still on your starter? Would NAPA be able to match you a starter with that information?
Ben W. in VA
OldPathsEquipment.com
Farmall Bob
PostPosted: Sun Jan 27, 2013 4:46 am    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
Hi Ben, It is a Delco Remy USA 1108311-3A-17 stamped on the body of the starter. It came off a Gravely Tractor I purchased and the man started it by turning the starter with his hand to a different location. It came off an L8 Gravely 1966. Thank you for your help.
Bob
Farmall Bob
PostPosted: Sun Jan 27, 2013 8:05 am    Post subject: Re: Gravely Tractor starter Reply to specific post Reply with quote
Hi Boomers, It is a 1966 Model L8 walk behind. Thank you.
Bob
