| Author |
Message |
Cooter23 New User
Posted: Sat Jan 26, 2013 1:08 pm Post subject: Montgomery Ward tractor, gilson 33048a? |
This message is a reply to an archived post by El Toro on August 21, 2012 at 09:11:35.
The original subject was "Re: Hyd pump on gilson 33048a?".
Morning all, My grandfather bought the 33048A brand new in 1971 as well. I have now acquired and bringing it back to life. Have successfully got the motor running well, however, struggling with the tiller model(GIL-33095A). When engage the PTO, the drive shaft spins, the tines spin on tiller, but when lower tiller/tines to begin tilling the tines stop upon touching the ground, however the drive shaft continues to spin. Originally thought the key-ways were gone. During tear down found key-ways still intact. I"m not sure if the problem is that the worm gear is worn or there"s other issues. I expect parts to be very scarce. Looking for any advice or if anyone out there has the tiller assembly for this model that they are willing to part with. Thanks for any assistance. Dave |
| Back to top |
El Toro Tractor Guru
Posted: Sat Jan 26, 2013 1:24 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
One of those tillers came with my tractor, but I traded it back to Wards for a rotary mower. It was too heavy for me to install. I always plow then use a Troy Bilt tiller. Hal
| Back to top |
Harvey 2 Regular
Posted: Sat Jan 26, 2013 1:57 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
I have some Montgomery Wards, but don't have anything but the mower decks.
Is that a home made hitch in back for the plow? The reason i'm asking, is the bracket on tractor covers up the decal and looks to be stationary. They are good looking tractors when painted up like yours.
On the gear shift models I haven't seen any that has the variable speed pulley still on them, evidently that part didn't last very long. |
| Back to top |
Cooter23 New User
Posted: Sat Jan 26, 2013 2:32 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
Very nice looking tractor. Mine is identical. Well, I should say I plan on painting it as nice as you have yours as soon as I finish finding parts.
I do not have the mower attachment. If I can figure out or find the right parts for the tiller maybe I can contact you again regarding a mower attachment.
Thanks for your time and information. |
| Back to top |
SuperABen Regular
Posted: Sat Jan 26, 2013 6:09 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
Remember that when you are sourcing parts, Gilson made the Montgomery Wards machinery. Gilson equivalents have interchangeable parts.
I sold a 1970 Montgomery Wards 14 gear drive a few weeks ago. They are heavy built tanks!
Ben W. in VA
OldPathsEquipment.com |
| Back to top |
Posted: Sat Jan 26, 2013 6:48 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
I kept the manual on the tiller. Hal
| Back to top |
Posted: Sat Jan 26, 2013 7:18 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
The plow is off a Viking walk behind tractor I bought in 1960. When I sold the Viking I kept the plow. To get the plow to work on the Wards tractor I had to make a template of the handles on the Viking. The hardest part was getting the bends the same. The bracket at the rear was copied off the Viking handles and the drawbar is
just of piece of metal bent 90° and welded to the plow bracket. When I first made it I used cap screws for mounting the bracket to the sleeve hitch. That was a pain so I made the bracket to fit the sleeve hitch using one pin.
The hydraulics on the tractor lifts and lowers the plow. Here are few pics of the plow bracket. You can still see the 4 tapped holes on the sleeve hitch. Hal
| Back to top |
Posted: Sat Jan 26, 2013 7:28 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
They used the same parts on the Wards tractors. Hal
| Back to top |
Harvey 2 Regular
Posted: Sat Jan 26, 2013 8:30 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
Thanks for the pictures of how you made the plow work. Around here where I live there wasn't any Montgomery Ward tractors that I knew of. I have some now and one that Gilson marketed as a Gilson, just painted different color than the Wards |
| Back to top |
Posted: Sun Jan 27, 2013 4:52 am Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
Here's the plow on the walk behind tractor. Hal
| Back to top |
REXBEAVERS Regular
Posted: Sun Jan 27, 2013 4:58 am Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
how is the pto belt is it loose an sliping an you put the tiller down an it put a little load on it an the pto turns the right speed but the shafts turns slower or it has to be in the gear box on the tiller it sleafi would out the gear box up .but first check the pto belt |
| Back to top |
Posted: Sun Jan 27, 2013 7:51 am Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
The paint I used was light color gold made by Dupont. It was their acrylic enamel and it was a mismatch that they had left over. The blue was New Holland's acrylic enamel. Paint is very expensive so is the thinner. Hal |
| Back to top |
Posted: Sun Jan 27, 2013 11:25 am Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
If you're referring to the sleeve hitch it's connected to a bell crank that's connected to the hydraulic cylinder for raising and lowering implements. Hal |
| Back to top |
Posted: Sun Jan 27, 2013 11:29 am Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
The sleeve hitch came with the tractor for lifting and pulling different implements. Hal
PS: It also has a Wards part number. |
| Back to top |
Cooter23 New User
Posted: Sun Jan 27, 2013 7:18 pm Post subject: Re: Montgomery Ward tractor, gilson 33048a? |
yes I thought the same thing at first as well. In fact the belt that was on there was to small. Replaced with correct size and still have the problem. Like you say, I think it's in the gear drive. I'm in Sacramento Ca. area. No of any guys that work on these older tractors that are inthis area? Thanks for help. |
| Back to top |
