proof meter 8n ford
Ronnie Lankford
PostPosted: Sat Jan 26, 2013 4:47 pm    Post subject: proof meter 8n ford Reply to specific post Reply with quote
I have 8n 1950yr model and been install new gages on it I put a new proof meter and cable on , and the meter do's not work? I know that there are two different cable length of cable 32" and 33". I beleive I used the 32". any suggestion?
oldtanker
PostPosted: Sat Jan 26, 2013 4:55 pm    Post subject: Re: proof meter 8n ford Reply to specific post Reply with quote
My best suggestion is to take this over the the Ford N page on.....yesterdays tractors!
Rick
View user's profile Yahoo Messenger
JD Seller
PostPosted: Sat Jan 26, 2013 4:56 pm    Post subject: Re: proof meter 8n ford Reply to specific post Reply with quote
Take the cable off the back of the hour meter. Start the tractor and see if the cable turns. If it is not then you may need a plastic adapter in the drive end. Some of the replacement cables do not fit the drive correctly and use a plastic adapter/filler.
If it is turning then spin the tach/hour meter with your fingers and see if it bounces. If it does then the cable is not the right one for your hour meter. If it does not bounce than your hour meter is faulty.
