| Author |
Message |
Russ from MN Tractor Expert
Posted: Sun Jan 27, 2013 10:00 am Post subject: Jonsered bar |
I have a Jonsered 621 and today I planned to buy a new bar & chain for it. L&M has a 20% off sale for 3 days, could of gotten one for $40, if it fit! They would of had to order the correct bar, so no sale price. They told me that the holes for the chain tensioning pin was different. Has anyone ever tried drilling a bar? I have a good drill press and some good drills. Thanks in advance. |
| Back to top |
guido Tractor Expert
Posted: Sun Jan 27, 2013 10:28 am Post subject: Re: Jonsered bar |
Hello Russ from MN,
The bar can be drilled, but you need to check the oil passage to it. The oil feed to the bar will be in a different spot when bolted to the saw.
Check the dimentions before you driil the bar.
I have drilled bars when the chain was still good but too loose to get tighten.
Guido |
| Back to top |
Awlknottedup Regular
Posted: Sun Jan 27, 2013 10:51 am Post subject: Re: Jonsered bar |
The Jonsered is made by Husqvarna and many bars are interchangeable. The bar on my CS2250 has a Husqvarna label. |
| Back to top |
Ellis Kinney Long Time User
Posted: Sun Jan 27, 2013 12:20 pm Post subject: Re: Jonsered bar |
There are drill bits to drill anything. Ellis |
| Back to top |
Butcher Regular
Posted: Sun Jan 27, 2013 12:25 pm Post subject: Re: Jonsered bar |
Both saws use an Oregon bar so save some dough and look there first. |
| Back to top |
JOCCO Long Time User
Posted: Sun Jan 27, 2013 3:27 pm Post subject: Re: Jonsered bar |
Russ it can and we have done it many times. Some older stihl bars would fit. It can be ordered too. |
| Back to top |
tomNE Long Time User
Posted: Sun Jan 27, 2013 7:04 pm Post subject: Re: Jonsered bar |
bars on amazon were half price of my local guys for the same bar! |
| Back to top |
Bret4207 Tractor Expert
Joined: 15 Jan 2005 Posts: 2899 Location: St Lawrence Valley, Northern NY
Posted: Mon Jan 28, 2013 4:01 am Post subject: Re: Jonsered bar |
The Jonsereds, the larger ones like the 621 anyway, use the same bar mount pattern as Husky, Dolmar, and several others. Baileys makes and adapter to use Stihl bars on Husky/Jonsereds saws.
Yes, they are fairly easy to drill, tough steel but not real hard. |
| Back to top |
RodinNS Tractor Guru
Posted: Mon Jan 28, 2013 9:37 am Post subject: Re: Jonsered bar |
That doesn't sounds like a particularly special price to me to begin with...
Why not just get the correct oregon bar and be done of it. If you change the position of the adjustment hole then basically you're extending the bar out beyond it's normal range... then you need an oddball chain with an extra driver...
I think I know exactly what bar you have too.... my firewood processor uses one like that. That particular bar saves me from buying a longer chain that I'd have needed to use a more standard stihl bar...
Rod |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
