Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Bad Bearing Right belt pulley shaft
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
L.LAMP
PostPosted: Sun Jan 27, 2013 11:35 am    Post subject: Bad Bearing Right belt pulley shaft Reply to specific post Reply with quote
What is the easiest way to replace this bearing on an SC?
TexasCC
PostPosted: Sun Jan 27, 2013 5:17 pm    Post subject: Re: Bad Bearing Right belt pulley shaft Reply to specific post Reply with quote
Trust me--where there's one bad bearing, there are many. This bearing under the belt pully is on the bevel gear shaft. If done correctly, any bearing replacement must involve resetting the backlash adjustment on the bevel pinion set. You could remove the belt pulley and the bearing carrier, cut the cage off the bad bearing and use a 3-jaw posi-lock puller to remove the inner race, heat the new bearing cone to around 300F and slide it on. An I&T service manual will give you just enough information to get you through setting up the dimensions on the shaft. You will have to pull the top transmission cover to access the gear set to do the job correctly. I would advise checking everything else carefully while you are in there. Best of luck!
