| Author |
Message |
Mean Green Regular
Posted: Sun Jan 27, 2013 3:11 pm Post subject: Good spark plugs for WD45 |
What are good spark plugs for a gas WD45? Champion or Autolite? Numbers? I know I have had better luck with the Autolites on my John Deeres. Thanks for the help. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50439 Location: Lake of the Ozarks area of MO
Posted: Sun Jan 27, 2013 3:17 pm Post subject: Re: Good spark plugs for WD45 |
I have champs in my WD45 but could not see the number on them. When and if I replace them I will go with auto lites |
| Back to top |
black Guest
Posted: Sun Jan 27, 2013 3:37 pm Post subject: Re: Good spark plugs for WD45 |
Old; Is there a problem with your champs ? or is your preference Autolites . My wd45 has champs and so far she pulls and parades good -- don't know the plug # off hand |
| Back to top |
Ted in NE-OH Regular
Joined: 28 Nov 2012 Posts: 266 Location: Austinburg Ohio
Posted: Sun Jan 27, 2013 3:58 pm Post subject: Re: Good spark plugs for WD45 |
Autolite 295 |
| Back to top |
old Tractor Guru
Posted: Sun Jan 27, 2013 6:06 pm Post subject: Re: Good spark plugs for WD45 |
Now days the Auto lites seem to work better with this crap gas we have now then the champs do. But the champs I have in this WD45 are the same ones that where in it back 10 years ago when I got the thing and as long as she runs well and does what I want I'll leave them there |
| Back to top |
BushogPapa Tractor Guru
Posted: Sun Jan 27, 2013 6:12 pm Post subject: Re: Good spark plugs for WD45 |
Maybe you just got real lucky and got a GOOD set of Champs...
Now..hope they come OUT when you want to change them..!!
Ron.. |
| Back to top |
old Tractor Guru
Posted: Sun Jan 27, 2013 6:26 pm Post subject: Re: Good spark plugs for WD45 |
I have had them out a few times doing what I call a poor mans tune up. I clean then regap them and put them in a different cylinder and go with it. It has had a hay rake on it for the last 2 or 3 years. Walked by it just the other day and turn the gas on and it started right up and it has been sitting in the filed since May when I did the hay this year |
| Back to top |
old Tractor Guru
| Back to top |
Posted: Sun Jan 27, 2013 7:05 pm Post subject: Re: Good spark plugs for WD45 |
Using Champions in my old 390 Ford taught me to always use "Never-Seize" on each and every one..!!!
Had the same experiences with them in a JD..
About twisted some off, getting them out..
Really thought I would at least bend the 1/2" breaker-bar..
Ron.. |
| Back to top |
old Tractor Guru
Posted: Sun Jan 27, 2013 8:51 pm Post subject: Re: Good spark plugs for WD45 |
Never had much problem with plugs sticking in the head but them I do not over tighten them. Shoot some times I have the opposite problem and forget to tighten them enough and have them blow out and when that happens they can be hard to find LOL |
| Back to top |
Kip-Utah Long Time User
Posted: Sun Jan 27, 2013 9:41 pm Post subject: Re: Good spark plugs for WD45 |
Your WD45 most likely has a distributor (battery) ignition. If so and it's in a good state of tune and not an excessive oil burner I would suggest Autolite 303. But 295s also work great and is what you should use if by chance you are running a magneto. Kip |
| Back to top |
Posted: Mon Jan 28, 2013 2:14 pm Post subject: Re: Good spark plugs for WD45 |
Something like that might give ya a heat attack..!!!
I do have a habit of getting things "MAN_Tight"...don't usually have bolts come loose either, but those Champs sometimes seem to seize in the threads and really can be severely hard to wrench out..ALL the way out..they Squeak and Squal all the way, each time you force them to move and you'd bet there were not going to be any threads when you get it out...
Like I said..I USE "Never-Seize" religiously on sparkplugs..!!!
Ron. |
| Back to top |
old Tractor Guru
Posted: Mon Jan 28, 2013 2:38 pm Post subject: Re: Good spark plugs for WD45 |
Learned many years ago to tight is as bad if not worse then not tight enough. |
| Back to top |
black Guest
Posted: Mon Jan 28, 2013 5:19 pm Post subject: Re: Good spark plugs for WD45 |
Ya , I'm always afraid of getting dirt in the cylinders , so I blow air to clean the head before removing the plugs . Your right Old , my wd45 also sits for months and fires right up -- a little choke and away she goes . I just have a straight pipe and I love the bark from that crater engine. |
| Back to top |
Ahod Guest
Posted: Thu Jan 31, 2013 5:15 pm Post subject: Re: Good spark plugs for WD45 |
i use a-c plugs in my d-17 and msd ignition and it eliminates all the problems your talking about |
| Back to top |
