Fordson super major information
bgarrett
PostPosted: Sun Jan 27, 2013 7:18 pm    Post subject: Fordson super major information Reply to specific post Reply with quote
A friend has asked me to help get this thing running. It has been sitting quite a while. I dont know about diesels and we will get the I&T manual but for now--how can we tell if the injectors are ok and where is the injector pump?
We cleaned the fuel tank and lines and replaced two fuel filters. It looked like the fuel pump with glass bowl was not working so we disassembled that and cleaned and tested the one way valves. seemed to pump well by hand, but we are not getting anything out of the fuel line where it screws into the head. I opened that line to allow air to bleed out but nothing is coming out. We appreciate anything you can tell us!
Majorman
PostPosted: Mon Jan 28, 2013 1:32 pm    Post subject: Re: Fordson super major information Reply to specific post Reply with quote
The pipe screwed to the cylinder head is the injector leak off pipe back to tank so you will not get fuel from there until the engine is running.
You first need to bleed the fuel filter via the vent screws on the top then bleed the fuel pump which is that lump on the side with four pipes going up to the head. There is a bleed screw on the side of the pump just under where the pipes fit.
If you cannot get fuel as far as the lift pump with the glass bowl it could be that the filter inside the fuel tap is blocked.
The fuel going to the pump and the filter must be completely air free and a good flow before the engine will start.
Once you have it running you can then worry about the injectors. If they need work it is best to take them to a specialist diesel repair shop along with the pump if needed.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
