| Author |
Message |
Red Pete Guest
Posted: Mon Jan 28, 2013 1:23 pm Post subject: Cuting fluid |
Anyone have a recipe or idea for cutting fluid? Been using Liquid Wrench or WD-40 for drilling holes in steel lately and it is ok but thought there might be something better. Used to use Mistic Metal Mover but lately it has gotten so expensive. Thanks |
| Back to top |
Bradracer18 Regular
Posted: Mon Jan 28, 2013 1:33 pm Post subject: Re: Cuting fluid |
We use Cool Tool II. Works Well. Not sure of the price |
| Back to top |
Brad Buchanan Long Time User
Hey Pete.
I have been using atf for drilling and cutting metal.
Seems to work as good or better than the genuine stuff. I just use whatever is in the shop and put it in a bottle with the cone tip.
Good luck,
Brad |
| Back to top |
gtractorfan Long Time User
Joined: 26 Sep 2011 Posts: 1184 Location: Van Wert, Ohio
Posted: Mon Jan 28, 2013 1:44 pm Post subject: Re: Cuting fluid |
Why not try used motor oil? Been doing that a long time. |
| Back to top |
cd1 Regular
Posted: Mon Jan 28, 2013 2:01 pm Post subject: Re: Cuting fluid |
Lots of options out there, pipe threading oil from the plumbing store is good. Then there is soluble oils. Different mists. Get a machinery catalog like travers or enco. |
| Back to top |
Ellis Kinney Long Time User
Posted: Mon Jan 28, 2013 2:26 pm Post subject: Re: Cuting fluid |
Tap Magic for steel, Lard for cast iron. Motor oil is not the answer, Think about what motor oil is supposed to do. Ellis |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50454 Location: Lake of the Ozarks area of MO
Posted: Mon Jan 28, 2013 2:36 pm Post subject: Re: Cuting fluid |
I use tread cutting oil when I cut metal comes in a can with a spout so you can drip it on. If I do not have that I use used motor oil |
| Back to top |
Tom-NoCenTX Guest
Posted: Mon Jan 28, 2013 2:45 pm Post subject: Re: Cuting fluid |
Brownell's DewDrill.
tom |
| Back to top |
Eric in IL Long Time User
Posted: Mon Jan 28, 2013 3:56 pm Post subject: Re: Cuting fluid |
The main idea when drilling steel is to keep the tool cool.
There is nothing better than water for this job.
Water soluble oil is added to keep the drill press and workpiece from rusting and provide limited lubricity.
We used WS 5050 from Rustlick at the tool & die shop. Mix at 25 parts water to one part WS 5050 or to suit your preferences.
Rustlick WS 5050
| Back to top |
Dick L Tractor Guru
Posted: Mon Jan 28, 2013 4:36 pm Post subject: Re: Cuting fluid |
You might be looking for this.
You can use a machine oil, chlorine, and sulfur.
When I first started doing machine work in the early 1960's it was what we used. I never made it myself so don't know the amounts. They melted the sulfur in a tin can and added it to the mixture.
The one below would be an easy one to mix up.
Things You'll Need
1 qt. of motor oil
3 cups of dish washing liquid
4 gallons of water
Instructions
1
Purchase the necessary products. Motor oil can be found at your local gas station and dish washing liquid at convenience stores and supermarkets.
2
Add the liquid soap to the water. Mix the soap into the water so that it is dissolved. The soap is the catalyst that will enable the oil and the water to mix; otherwise the different densities will make the oil float on top of the water.
3
Pour in the motor oil. Make sure that the water and the oil are mixed properly together with no separation. The water will act as a coolant in the cutting oil, while the oil acts as the lubricant, as the water is evaporated off by the heat generated in the cutting process.
Read more: How to Make Cutting Oil eHow.com http://www.ehow.com/how_6860630_make-cutting-oil.html#ixzz2JJtO8LcW |
| Back to top |
504 Tractor Expert
Posted: Mon Jan 28, 2013 5:23 pm Post subject: Re: Cuting fluid |
Slow cutting, water is what the old timers say to use. |
| Back to top |
wd9garymn Guest
Posted: Mon Jan 28, 2013 6:31 pm Post subject: Re: Cuting fluid |
for tapping holes i use regular vegetable oil from the grocery store. haven't tried it for drilling holes--guess i don't drill a lot of holes on the drill press |
| Back to top |
D beatty Regular
Posted: Mon Jan 28, 2013 7:39 pm Post subject: Re: Cuting fluid |
I use thread cutting oil.My uncle used a water based solution in his tool and die shop. |
| Back to top |
retired farmer Long Time User
Posted: Mon Jan 28, 2013 7:45 pm Post subject: Re: Cuting fluid |
I had been using a chain and cable spray for oiling the baler chains, when one day I finally read what was printed on the label. Said it could be used for drilling and tapping. Tried it and it works as good as Tap Magic. Don't remember the name. |
| Back to top |
ralph1111 Regular
Posted: Mon Jan 28, 2013 7:53 pm Post subject: Re: Cuting fluid |
Dosen't any one use chain saw bar oil? |
| Back to top |
