What Is It?
Michaels Dad
PostPosted: Mon Jan 28, 2013 2:43 pm    Post subject: What Is It? Reply to specific post Reply with quote
Been finding these around the property, mostly nailed to trees where a previous had cross fencing for goats.
It has a number on it ( googled it ) but nothing came up. Number is:
3842872-GM124A.
It's not a turnbuckle, it has right hand threads on both ends.
Jimmyjack
PostPosted: Mon Jan 28, 2013 3:12 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Kinda looks like a female threaded bolt.
Mal(Pa)
PostPosted: Mon Jan 28, 2013 3:24 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Looks like I've seen on a car's front suspension
Trac1
PostPosted: Mon Jan 28, 2013 3:35 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Not sure where you came up with the "female" in that picture?
john in la
PostPosted: Mon Jan 28, 2013 3:43 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
That sure looks like a upper cross shaft for a cars front end.
Anon
PostPosted: Mon Jan 28, 2013 4:14 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
IF memory serves me right, looks like upper control arm shaft for 70's/80's C10/C20 Chevy pick up.
Stephen Brussell
PostPosted: Mon Jan 28, 2013 4:58 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Definitely a upper control arm shaft from who knows what GM
car/truck.
Pops1532
PostPosted: Mon Jan 28, 2013 5:11 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Definitely an upper A frame cross shaft.
Greg1959
PostPosted: Mon Jan 28, 2013 5:36 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
You say you found a few around your property. Looks kinda like something a electrician/electrical person would use.
Just a guess...
Pops1532
PostPosted: Mon Jan 28, 2013 6:14 pm    Post subject: Re: What Is It? Reply to specific post Reply with quote
Greg1959 wrote:
(quoted from post at 01:36:19 01/29/13) You say you found a few around your property. Looks kinda like something a electrician/electrical person would use.
Just a guess...
If you google GM124A it shows results for Hubble electrical connectors which are nothing like the control arm cross shaft the OP posted. And according to the GM Parts History catalog posted on Wiki that part number was discontinued prior to Dec. 1990.
MarkB_MI
PostPosted: Tue Jan 29, 2013 3:02 am    Post subject: Re: What Is It? Reply to specific post Reply with quote
Of course it's a shaft for an upper control arm. The seven digit part number indicates an older GM part. Probably the previous owner of your property got a good deal on a bunch of reject parts and thought they were just the ticket for goat fencing.
JF in MI
PostPosted: Tue Jan 29, 2013 5:08 am    Post subject: Re: What Is It? Reply to specific post Reply with quote
Most are correct. It is a upper control arm pivot for an early chevrolet (early 50's) or (53-62 corvette). The threaded ends were for the screw on greaseable metal end bushings. Later on GM went to rubber bushings which slid on (no threads) and were retained with bolts and formed washers. Replaced many of those in a former life.
Jim
