| Author |
Message |
OldMoIron Regular
Posted: Mon Jan 28, 2013 4:15 pm Post subject: Headlight gromment |
Where can the plastic, or hard rubber be gotten that goes directly under the headlight housing and above the clamp that holds the healight to the crosss bar?
On a 53 super C Farmall |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18243 Location: St. Cloud, MN
Posted: Tue Jan 29, 2013 6:26 am Post subject: Re: Headlight gromment |
The parts diagrams are off line this morning, but I have no recollection of a component as you describe. Those pancake lights we have are directly mounted to the clamp. Jim |
| Back to top |
Farmallhal Tractor Expert
Joined: 16 Oct 2004 Posts: 1783 Location: Rolla, Missouri
Posted: Tue Jan 29, 2013 7:31 am Post subject: Re: Headlight gromment |
Jim, I looked in my Super C parts catalog (paper copy) and there isn't anything like what is described in this thread shown. Just the flat back light assembly with the spacer, clamp, washer and nut. He might have had one to keep from marring paint and if that is the case a washer from one of those hardware store small parts drawer should suffice. For that purpose one from some rubber product, plastic and even a fiber one would be fine, Hal. |
| Back to top |
OldMoIron Regular
Posted: Tue Jan 29, 2013 4:31 pm Post subject: Re: Headlight gromment |
I think it would be the spacer, but I wasnt sure exxactly what it was called, thanks |
| Back to top |
Posted: Tue Jan 29, 2013 5:49 pm Post subject: Re: Headlight gromment |
If you are referring to the spacer it will be steel and about 3/8" to 1/2" or so long with a hole a little larger then the 1/2" stud on your lamp to slide through. The outside diameter is probably around 3/4" or maybe a little smaller (not near one to measure). The spacer goes between the lamp housing and the lightbar clamp with a split locknut and hex nut on the bottom. Spacers are available from about anyone who sells parts for the letter series tractors. Hope this helps, Hal. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
