| Author |
Message |
Brad in WI Long Time User
Posted: Mon Jan 28, 2013 6:15 pm Post subject: Removing brake drum on an H |
I am trying to remove a brake drum and it is not co-operating with me. I have the early style drum that has the the key. So far I have only tried prying it off with bars opposite of each other (worked on other side) and applying minimal heat with a propane torch. Any suggestions on what else I can do to remove the drum? I am putting in new bearings and seals so I am not worried about burning them with a hotter heat source. I do not have a puller but might be able to find one if that is the only option to get it apart. |
| Back to top |
S2710 Long Time User
Joined: 08 May 2008 Posts: 946 Location: West central Wisconsin
Posted: Mon Jan 28, 2013 6:56 pm Post subject: Re: Removing brake drum on an H |
Brad and if you screw the drum up I have a pair of them with the key slot in them. I am in western wi. by LaCrosse.
Bob |
| Back to top |
Zachary Hoyt Tractor Expert
Posted: Mon Jan 28, 2013 7:31 pm Post subject: Re: Removing brake drum on an H |
I have parted out several and have found that sometimes a wedge
driven in on two sides will do it. If you can get the whole thing to
move a bit toward you then you can put the bolt back in the drum
while leaving the retainer off and hit the head of the bolt with a
heavy hammer, which sometimes will get it started.
Zach |
| Back to top |
Posted: Tue Jan 29, 2013 4:36 am Post subject: Re: Removing brake drum on an H |
I meant to say put the bolt back in the pinion shaft not the drum.
Zach |
| Back to top |
The Red Tractor Guru
Posted: Tue Jan 29, 2013 9:29 am Post subject: Re: Removing brake drum on an H |
I had to use a 3 claw puller on one of my Hs. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
