VAC-13 rear light
connor9988
PostPosted: Mon Jan 28, 2013 6:47 pm    Post subject: VAC-13 rear light Reply to specific post Reply with quote
Where does the rear light on a VAC-13 mount?
Thanks.
Case Nutty 1660
PostPosted: Mon Jan 28, 2013 6:55 pm    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
blow this pic up and to the left of the Eagle hitch cylinder you can see a "L" bracket with two holes one hole is for the light to mount the other is for the thrid link hitch pin with a chain attached for holding the link when nothing is hooked to the Eagle hitch, this is a 1951 VAC
connor9988
PostPosted: Mon Jan 28, 2013 7:02 pm    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
What does that "L" bracket mount to? The seat?
Case Nutty 1660
PostPosted: Mon Jan 28, 2013 7:44 pm    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
looks like the seat base has a bracket welded to it I can get a better pic in the morning if you like
rbradk
PostPosted: Tue Jan 29, 2013 2:36 am    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
That is an easy ride seat assy. If you have the standard seat the L bracket mounts to the hole below the hinge pin that allows you to tip the seat up, It is a 1 x 5 or so L bracket with two holes on the 5" side. Outside for the light, inside for the top link chain.
connor9988
PostPosted: Tue Jan 29, 2013 4:14 am    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
You don"t have to post another picture. I don"t have the easy rider seat but I understand how it mounts now.
Thank you very much.
Case Nutty 1660
PostPosted: Tue Jan 29, 2013 2:27 pm    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
here is a shot of my VA's light bracket witht he std seat
connor9988
PostPosted: Tue Jan 29, 2013 2:31 pm    Post subject: Re: VAC-13 rear light Reply to specific post Reply with quote
That helps a lot. Thank you!
