Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
3 in journel on a stroker crank hold togeather
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
big G puller
PostPosted: Tue Jan 29, 2013 8:41 am    Post subject: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
will a 3 journel on a 9.5 stroker crank with a 7 3/4 bore hold togeather or break?
Lynerd
PostPosted: Tue Jan 29, 2013 9:20 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Yes Lynn
Josh Blackburn
PostPosted: Tue Jan 29, 2013 9:28 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Why risk it. 5020 3.5 journal. You can still fit 9.5 in easy.
Mike N Mo
PostPosted: Tue Jan 29, 2013 9:34 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
You'll be better off with a 3.375-3.5" journal size. The 3" will hold for a while, but the bigger ones will last a lot longer.
big G puller
josh how much to do a 9.5 or 9.75 with 3.5 journels
Brent50G
PostPosted: Tue Jan 29, 2013 1:45 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Yes for a couple years as long as u keep it from detonating
blackangus
PostPosted: Tue Jan 29, 2013 7:58 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Ive got a3.5/8 with 3.5 journal in my 70 very tight
Josh Blackburn
PostPosted: Wed Jan 30, 2013 4:25 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
1500 includes flywheel-crank-driver assembly balanced as one unit.
Tree Topper
PostPosted: Wed Jan 30, 2013 11:10 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
I have a 9.75 stroke, 6.375 bore, about 9 to 1 compression. Been running since 2004 with no problems yet. Has been pulled pretty hard in 10,200 lb. class many times. Works real well.
Oh yes it has a 3 inch journal!
buickanddeere
PostPosted: Wed Jan 30, 2013 12:20 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
She has to last in order to place first
Mike N Mo
PostPosted: Wed Jan 30, 2013 1:27 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Tree Topper, Your 3" journal should be very reliable at 622 cu in. We're running 3" journals on A's with more cubes than that, and just replaced a crank after 6 years (before it broke). The engine in question will have 896 cubes, almost half again more than yours, and needs the bigger journal to have decent reliability. Mike
Big G puller
PostPosted: Wed Jan 30, 2013 3:41 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
well iv been running this crank for 7 yrs with 3 in journels 7.5 block thats 832 cubes block went bad so if im gonna replace block to 7 3/4 im going with a new crank shaft befor it breaks
buickanddeere
PostPosted: Thu Jan 31, 2013 5:17 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
A 3.5" journal has 1.361 times more material than a 3.0" journal.
Tree Topper
PostPosted: Thu Jan 31, 2013 9:54 am    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
Yes I know this is not a very big G as compared
to what is being built these days, but this set up has worked very well for me. Been very reliable. Don't use the engine up very often even in heavy classes. Lots of fun.
Indiana Ken
PostPosted: Thu Jan 31, 2013 7:12 pm    Post subject: Re: 3 in journel on a stroker crank hold togeather Reply to specific post Reply with quote
buickanddeere wrote:
(quoted from post at 06:17:31 01/31/13) A 3.5" journal has 1.361 times more material than a 3.0" journal.
Yes, this would be correct for cross sectional area. The strength of the journal in tension is proportional to the cross sectional area. However, for a crankshaft, strength in torsion and strength in bending are more important than strength in tension.
If I could repeat your calculations for clarity: The cross sectional area is proportional to the diameter raised to the second power (diameter squared). For a 3" journal we have 3^2 = 9 and for a 3.5" journal we have 3.5^2 = 12.25. 12.25 divided by 9 = 1.361; increase in strength in tension.
The strength of the journal in torsion and in bending is proportional to the journal diameter raised to the fourth power. For a 3" journal we have 3^4 = 81 and for a 3.5" journal we have 3.5^4 = 150.06. 150.06 divided by 81 = 1.85; increase in strength in torsion and bending.
In conclusion the 3.5" journal is nearly double in stength for the more important torsion and bending modes.
With all respect - hopefully this adds to your post. Ken
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
