Parts found in drained Hy-Tran on a 706
John V.
PostPosted: Tue Jan 29, 2013 12:08 pm    Post subject: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
Does anybody know or have an educated guess as to what these parts are from. I replaced the Hy-Tran and put a new hydraulic filter in the tractor and I found these sitting in the bottom of the drain pan. The bushing is 1/2 in. I.D. Any help would be appreciated.
oliverdieselpuller
PostPosted: Tue Jan 29, 2013 12:15 pm    Post subject: Re: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
The roller is off of the shift qaudant. Seem many come off. No clue on the pin.
mkirsch
PostPosted: Tue Jan 29, 2013 12:17 pm    Post subject: Re: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
My first guess would be parts off the underside of the range transmission cover. Operators are particularly rough on the range transmissions in 06 series tractors. Things get broke.
John V.
PostPosted: Tue Jan 29, 2013 12:38 pm    Post subject: Re: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
Could this explain why I hear a knock when then transmission is in low range, like it isn't fully engaged?
Jim Naden
PostPosted: Tue Jan 29, 2013 1:59 pm    Post subject: Re: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
The pin is from the range shift cam, was recommended to safety wire the pin after assembly to contain the pieces so they didn't escape when it eventually broke.
John V.
PostPosted: Tue Jan 29, 2013 2:36 pm    Post subject: Re: Parts found in drained Hy-Tran on a 706 Reply to specific post Reply with quote
Thanks for the replies, this gives me some stuff to look into.
