| Author |
Message |
Zjames New User
Posted: Tue Jan 29, 2013 5:45 pm Post subject: Farmall 560 valve adjustment |
I want to adjust the valves in my 560 is there a timing pin that I need to make sure it's at tdc? Tia |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18247 Location: St. Cloud, MN
Posted: Tue Jan 29, 2013 6:03 pm Post subject: Re: Farmall 560 valve adjustment |
Valve Adjust by Jim --- It is simple and fool proof. The process works for all engines with adjustable poppet valves and any number of cylinders. Identifying the valve order is all that is necesary (given in this process for the IH 6 cyl gas).
I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal Get the specification.
Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open.
Set the exhaust when the intake just closes.
These are the two positions that can be seen at the springs and retainers for each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is.
The order is (front to back EI-IE-EI-IE-EI-IE)
Look at #1 valves, Turn the engine till the Exhaust just starts to begin opening (moves) then adjust the Intake valve. Rotate more until the intake just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above) the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Jim |
| Back to top |
rustred Tractor Expert
Posted: Tue Jan 29, 2013 6:37 pm Post subject: Re: Farmall 560 valve adjustment |
the spec. is .027 hot.
i adjust valves according to the firing order,
1 5 3
6 2 4 and do both valves for that cyl.when on tdc. on compression.
this is the way i was taught in class 36 years ago. but lots more to procedure. |
| Back to top |
Zjames New User
Posted: Tue Jan 29, 2013 8:31 pm Post subject: Re: Farmall 560 valve adjustment |
Ok thanks for the help. I thought of another question related to the topic. How did you go about turning the engine over by hand? I have not worked on a lot of red. I use a special flywheel tool to turn the flywheel ? Thanks |
| Back to top |
Posted: Tue Jan 29, 2013 9:05 pm Post subject: Re: Farmall 560 valve adjustment |
i have a crank for that engine, hard to find them. |
| Back to top |
Posted: Tue Jan 29, 2013 9:21 pm Post subject: Re: Farmall 560 valve adjustment |
With the plugs out it is usually easy to turn the engine with the fan. Sometimes necessary to push in on the belt while doing so. Another way is to lift one tire and put it in 5th with the TA ahead. That allows easy rotation. Jim |
| Back to top |
Jim Naden Regular
Joined: 03 Jul 2012 Posts: 87 Location: South Eastern Tipton County Indiana
Posted: Tue Jan 29, 2013 9:38 pm Post subject: Re: Farmall 560 valve adjustment |
| Zjames wrote: | | (quoted from post at 18:45:07 01/29/13) I want to adjust the valves in my 560 is there a timing pin that I need to make sure it's at tdc? Tia |
Easy way....
(timing marks on front pulley)
With engine turned to #1 TDC adjust valves (numbered front to back) 1,2,3,5,7,9
Turn engine one revolution to #6 TDC and adjust valves 4,6,8,10,11,12
Best results are obtained with engine stabilized at room temperature. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
